Post 109197 by clint eastwood on 2006-05-18 22:18:58
Is there a simple method off getting a twist out of a seatbelt.cheers:Handshake
[QUOTE=clint eastwood]Is there a simple method off getting a twist out of a seatbelt.cheers:Handshake[/QUOTE] twist it back the other way ? sorry - had to be said :troutslap
lol, yep - unwind it completely as far as it will go, then straighten it the correct way round, then feed it back in slowly so you dont allow the twist to re-occur. the trick is to unwiind it fully before you try :)
The other option is to undo the seat belt at the point where its fastened to the car/seat , straighten it, then re attach it!.
