Post 112278 by clint eastwood on 2006-05-27 21:41:30
Can a "bleed valve" be fiitted to my T-5, and if so what wouuld be the supposed power increase, what is the cost? Cheers:Handshake
Yes it can, don't do it though, bleed valves are nasty rubbish things. If you do want a quick rise then fit an MBC (Mechanical Boost Controller) such as a Dawes device, GBE, etc etc, a ball and spring type controller. These are much better than a bleed valve and cost around £35-£55 depending on the one you go for. Ask on here for what the safe level to increase the boost to is though, and ensure you have a bost guage in order to set it properly. Ross
Agreed, as long as they are used with respect, good bang for buck ! Chris
