Post 112636 by dreadly on 2006-05-29 21:27:10
Some of you may remember I posted a couple of months ago to say my T5 was getting harder to start... I finally get the time and inclenation to change the spark plugs for a new set of platinum's from PFVO I purchased a couple of months ago. As I was removing number three, I noticed it turned without any pressure and there was black gunge blown up the inside of the plug access hole and number one and two have turned a very bright white and are covered in a white powder ??? After installation of the new plugs it ran sweeter than ever and has much more tourque. Why would plugs one and two go white? - I presume it's heat? I can only imagine the dealer did'nt do number three up properly, or it came loose over time. The plugs I removed are the originals from the factory, so should never have been removed yet as the car only has 23K miles, I have never seen this before, ahve any of you guys/gals?
