Post 112993 by dreadly on 2006-05-31 14:09:15
In your opinion as fellow T5 drivers, is it worth the extra money to upgrade the brakes on my V70 T5 from the standard 285mm to 302mm from Vovlo ?
The car is a standard 1999 V70 T5 Est.
The brakes all need replacing anyway, quoted £234.30 for All Disks/pads/shoes etc... - To upgrade to 302mm it will cost another £98.81 from Marshals.
Any opinions greatfully received.
Post 112995 by t5owner on 2006-05-31 14:13:56
If your gonna mod it with a rica ecu upgrade then i`d say yes spend the bit extra and upgrade the brakes and don`t forget you will need a set of braided hoses as well as the standard ones are not long enough once you`ve moved the calipers out
If your not modding it then just uprate the brakes with grooved/drilled discs at the standard size
Cheers
stuart
Post 112996 by dreadly on 2006-05-31 14:19:57
Believe it or not, that price includes the hoses as well.
Post 112997 by t5owner on 2006-05-31 14:31:38
[QUOTE=dreadly]Believe it or not, that price includes the hoses as well.[/QUOTE]
Then you might as well go for it mate at those prices
Cheers
stuart
Post 112999 by dreadly on 2006-05-31 14:36:07
Has anybody ever bought the cheapy disks from GSF etc... The one's that seem to rust in a few days ?
Post 113000 by Baj on 2006-05-31 14:36:15
Isnt there a wheel/clearance issue to take into account?
Post 113001 by BlackBeast on 2006-05-31 14:38:03
Thats a very good price, my front discs alone will cost £172 :(
Post 113004 by dreadly on 2006-05-31 14:48:52
[QUOTE=Baj]Isnt there a wheel/clearance issue to take into account?[/QUOTE]
Oliver told me not on the 16" wheels, clearance is a problem on 15" wheels.
If anybody knows otherwise then please tell...
Post 113010 by t5owner on 2006-05-31 15:19:59
[QUOTE=dreadly]Oliver told me not on the 16" wheels, clearance is a problem on 15" wheels.
If anybody knows otherwise then please tell...[/QUOTE]
The problem can arise if you have 16" columba`s on your V70 but you should have 16" Perfo`s like mine so you should be ok as i beleive VikingT5 has the 302mm discs on his V70 and he only has 16" Perfo`s on so clearence is not an issue with those wheels
Cheers
stuart
Post 113011 by t5owner on 2006-05-31 15:20:50
[QUOTE=BlackBeast]Thats a very good price, my front discs alone will cost £172 :([/QUOTE]
Jesus steve
What discs you putting on
Cheers
stuart
Post 113012 by t5owner on 2006-05-31 15:23:29
[QUOTE=dreadly]Has anybody ever bought the cheapy disks from GSF etc... The one's that seem to rust in a few days ?[/QUOTE]
You could always get a tin of aluminium paint from wilkos 99p i paid and just paint up the hub part once the discs are on i did this on my S70 and they still look good as new (well the hubs do)
Cheers
stuart
Post 113037 by Tomcat on 2006-05-31 17:40:03
[QUOTE=dreadly].
QUOTE]
Was that price for the rears as well?, and who did you get the price from?, I'm wanting to upgrade my brakes to 302's but I need to replace the rears at the same time as they're shot too.
Post 113061 by dreadly on 2006-05-31 18:42:13
[QUOTE=tomcat][QUOTE=dreadly].
QUOTE]
Was that price for the rears as well?, and who did you get the price from?, I'm wanting to upgrade my brakes to 302's but I need to replace the rears at the same time as they're shot too.[/QUOTE]
£234.30 is the cost for all genuine vovlo parts from Marshals, including Next day delivery - or thereabouts...
the 98.81 is the extra cost of the 302mm upgrade, so that's 302mm disks instead of the 285mm one's and a 302mm caliper hanger set and the hoses.
So total cost of the 302mm upgrade + Rears would be £333.11 (This includes all handbrake shoes + Fitting kit aswell, so you shouldn't need anything else other than a pot of copper grease for all four wheels.
Post 113080 by dreadly on 2006-05-31 19:48:38
Maybe Marshals could better this price somemore??? :biggrin:
Post 113093 by blackbooty on 2006-05-31 20:11:50
[QUOTE=dreadly]Maybe Marshals could better this price somemore??? :biggrin:[/QUOTE]
marshalls- Wayne, is temp offline bud, little holiday i think.
email the shop mate.
Post 113096 by BlackBeast on 2006-05-31 20:14:04
[QUOTE=t5owner]Jesus steve
Cheers
stuart[/QUOTE]
S60R front discs, its the price you have to pay for 4pots upfront. But then, they are much cheaper than AP replacement rotors.
Post 113099 by Unknown on 2006-05-31 20:22:14
[QUOTE=dreadly]In your opinion as fellow T5 drivers, is it worth the extra money to upgrade the brakes on my V70 T5 from the standard 285mm to 302mm from Vovlo ?
Any opinions greatfully received.[/QUOTE]
..basically bigger is better.
If your doing track days. Say several every 6 months or so then YES, BIGGER.
If your a Fast road driver then get the best DISCS that you can afford at 280mm (Tar-ox disks). 6 "vanes" or grooves so be enough, dont go 8 - 12 coz you might not get enough heat in the brakes to make them work efficently on road use.
Edski
Post 113111 by Straker on 2006-05-31 20:38:32
Dude for an extra £90 odd quid go for it. Well worth it. Bigger brakes not only stop better but will dissapate heat better also. If everything needs doing go for it. I have just done mine and am very pleased with the results!
Post 113221 by Wobbly Dave on 2006-06-01 09:20:46
[quote=barberecpw]..basically bigger is better.
Edski[/quote]
I agree - not worth doing for just road use. Better to save the money and invest in decent pads - namely Ferodo DS2500 and some decent quality disks. Had 250bhp on my 855R auto and 280mm disks and DS2500s. Stopping was never an issue. I had the 280mm plain Brembo disks.
Bit curious if you have a V70 1999 why you havent got the 302s already? How odd.
BTW it doesnt matter how much power you have - energy required to stop the car remains the same. Remapping does not add weigh/momentum to the car.
