Hi-level Brake light intermittant.....
Post 121729 by adriancole on 2006-07-04 15:11:11
Well it was intermittant and now has stopped, so i presume that a wire has chaffed somewhere......is there a normal place for this to happen on a 1999 V70?? Light does still work if connected to a power source.... Checked the connector at the light, though am on south coast and no torx stuff to undo the rear panel at the moment.... So, chaffed wires?? any other connection on the tailgate? many thanks adrian
Post 121739 by Straker on 2006-07-04 15:53:46
Mine had this for a while and then stopped working all together. After much investigation it was the bulb that had gone. For the sake of £1.5 from halfords start with that.
Post 121797 by adriancole on 2006-07-04 18:08:57
Mine seems to be one of those LED Jobbies or am i mistaken, anyway it still works if connected to a power supply......
