Post 123014 by starion on 2006-07-07 23:56:43
Hi, I hope someone can help. My V70 D5 pulls to the right under acceleration and twitches back to the left when you take your foot off!! Is this normal??? I have had the tracking checked and it seems to be ok, tyres, etc ok.
The only car I`ve driven before that I could compare this to was an old escort turbo, surely not!!!!
Any suggestions please????
Post 123044 by t5 stealth on 2006-07-08 03:19:00
have you had the front suspension lower arm bushes checked,
inner bushes mite be worn so the lower arms can move about which alters the direction of the wheels,accelerating makes the arm move in one direction then braking or decelerating moves the arm in the other direction,
hope that helps
Post 123063 by Redbrick on 2006-07-08 09:30:02
I've driven four in the last couple of weeks and none of them did that, not even the Rica'd one.
I read there is an issue with bushes as t5 stealth has already said.
Post 123130 by starion on 2006-07-08 15:07:22
Thanks for the info guys! Do you know anywhere that might do poly bushes or something?
Thanks again.
