front door speakers?
Post 127765 by Paul on 2006-07-22 21:14:59
right my top door speakers magnet has came loose sounds awfull in bass been told to upgrade the upper speaker on each door anyone know what size they are? any suggestions to which ones i should get? any links?
Post 127905 by T-5ones on 2006-07-23 11:37:04
Sorry, dont know which car you've got... I've got V70p1/850? two original door speakers, somewhwere. If you are after the upgraded speakers I installed a kenwood set that fitted and can have a look at the old box for the sizes and details for your info. The upgraded speakers are not recomended for the standard headunit but as I put in a complete new system it didnt matter.
Post 127985 by Paul on 2006-07-23 16:59:13
yea i have a new headunit and its a volvo c70
Post 127998 by T-5ones on 2006-07-23 17:38:28
Found them! I have the original door speakers (2x) 156mm diameter for the P+P if you want them. I used Kenwood KFC-PSR70P upgrade with the amp and new headunit. [URL="http://www.kenwood.com/i/products/audio/car/kfcpsr70p.html"]http://www.kenwood.com/i/products/audio/car/kfcpsr70p.html[Linky]
Post 127999 by T-5ones on 2006-07-23 17:45:53
I used this kenwood set with my system upgrade. I think it fitted without alteration but not absolutely sure. http://www.kenwood.com/i/products/audio/car/kfcpsr70p.html They are stated as 6 1/2" /170mm in size. I have the two original volvo door speakers for the P+P if reqired. (165mm diameter.) Also have all the cables, 3 amps etc from the system if any one interested.
