subs
Post 132801 by pitslayer on 2006-08-09 21:57:27
has the standard, cd tape deck got a remote cable? ive got a sub setup in my golf and was wondering if i can stick it all the boot of an S40, without changing the proper orignal cd tape deck?
Post 132826 by mulletboy2 on 2006-08-09 22:52:01
On the off-chance that it doesn't, you could always use the ignition switched live - it just means that the amp'll be on whenever the ignition's on rather than whenever the stereo's on ..
Post 132831 by arbee on 2006-08-09 23:26:36
or pop in an line switch somewhere in the dash area if you want the facility to turn it off when the ignition is on.
Post 132847 by pitslayer on 2006-08-10 02:41:25
does it have RCA cables outputs aswell? forgot to ask that
Post 132849 by arbee on 2006-08-10 07:16:11
[QUOTE=pitslayer]does it have RCA cables outputs aswell? forgot to ask that[/QUOTE] I'm fairly sure it wont, tho if you need to, a feed can be taken from the speaker output, either straight to the amp if it has the fcility or via a little converter box
Post 132850 by TwistedSanity on 2006-08-10 07:37:04
remote power switch------electric arial?(spelling)
Post 132851 by arbee on 2006-08-10 07:42:14
[QUOTE=TwistedSanity]remote power switch------electric arial?(spelling)[/QUOTE] not sure about volvos but they tend to come on only when the radio is on and go off when cd/tape is in use
Post 133024 by pitslayer on 2006-08-10 17:42:34
anyone have a how to on this? i can wire a cd player and subs up no problem, but when it comes to fixed units i have no idea. cheers for the help and input much appreciated. for the remote cable i could take it off the cd player power input for when ignition comes on, so when it turn ignition on, the cd player will come on and off that wire in the remote to the amp and have it come on through there? cheers
Post 133061 by arbee on 2006-08-10 20:08:05
yeah thats what mullethead was suggesting, probably the best idea, have a llok if your amp has speaker level inputs, if not something like this will do http://cgi.ebay.co.uk/FLI-Line-Level-Convertor-Speakers-into-RCA-Only-7-50_W0QQitemZ220016056325QQihZ012QQcategoryZ14932QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Post 133636 by flyinglemur on 2006-08-13 00:08:50
Just take the wire from the aerial. Taht's what the remote trigger was for
Post 133642 by M44K TS on 2006-08-13 00:40:12
i took a remote live from the cd changer wiring, only thing i'd say about the aerial, doesthe power not get turned off to it once its fully extended?
Post 148405 by Benji on 2006-10-04 00:01:19
can you take a photo of the back of your headunit with the power block plugged in should be able to work out which you could use for remote, unless you fancy waiting till i have my own volvo lol
Post 148415 by M44K TS on 2006-10-04 01:10:05
i reckon the cd changer is the best bet, it's powers up with the head unit and if you connect it to the aerial, it might cause interference to the reception
Post 149742 by madleee on 2006-10-08 18:08:34
anyone seen or made a sub unit to fit in the spare tyre well of an 855? Has to have a kick grille on it 'cos it's going in a seven seater?
Post 149965 by Benji on 2006-10-08 22:58:35
why not build a false floor to cover it and put holes in it
Post 150055 by madleee on 2006-10-09 07:47:45
I could use the ply floor that fits over the space saver now?
Post 150056 by adriancole on 2006-10-09 07:48:40
[QUOTE=madleee]anyone seen or made a sub unit to fit in the spare tyre well of an 855? Has to have a kick grille on it 'cos it's going in a seven seater?[/QUOTE] Yup, though i am not sure it will fit with a seven seater unless you compromise on the size of the sub or loose the two extra seats...... Volvo do one, though not poss to fit it with seven seats... Image Pic of one.....
