Dash top removal(P1 V70 no passenger airbag)
Post 133177 by Vikingxl on 2006-08-11 06:59:08
Ok first things first you will require a small flat bladed screwdriver a piece of cloth and a torx set Ok step 1 is to disconnect the battery and wait about ten minites for the airbag to disarm Then open the glovebox and remove the six torx screws on the front of the insert and remove it. Now open both doors to get to the side vents and using the cloth and the small screwdriver slowly prise these both out. Image Next do the same with the speaker grills Image Then the air vents on both sides Image And the middle Image Now its time to remove the torx screws One from each side here Image One from each side here Image Then two from here Image Two from here(top of the clocks) Image And finally two from the underside of the dash in the glove box Image Image Then its just a matter of pulling the dash forward and then lifting it out Image
Post 133179 by abdul on 2006-08-11 10:51:49
excellent how to
Post 133185 by fraz13 on 2006-08-11 11:41:46
Nice one Rich, This should help alot ;)
