What Have I done?
Post 135423 by Bigtony on 2006-08-18 14:15:44
Hi guys Its the crazy DIYer here again, On monday I took off my inlet manifold to sort out the breather system (PCV) this was done quite easily and the breathers are fine now. I replaced my inlet manifold (a 95 one) as mine looked a bit worse for wear :). The time then came to start up.......the engine kicked into life then died, tried again the same thing (wont idle) I put a little revs on it the next time it revved but then it started coughing and spitting (you could hear it popping in the manifold). I immediately thought it was the manifold so I took it all back down and put my original manifold back on, the same problem still. I have checked all wires leads etc, cant find any fault - I then took the plugs out (these are new about a week old) and they stank of petrol seams that they are folded I am going to change them by tomorrow and try again. Has anyone ever had this problem? any ideas as to why this happend in the first place?]
Post 135425 by t5tart on 2006-08-18 14:17:46
check maf sensor connection and idler control valve
Post 135429 by Bigtony on 2006-08-18 14:23:50
checked and double checked I even cleaned out the idler - are the connections the same? could it be that I have plade the wrong plug on the wrong bit? what is the connection on the trottle body for?
Post 135430 by t5tart on 2006-08-18 14:25:02
ure but you could have grossed them over but it would make one a bit tight on the wire wouldnt hurt to try swap them and see if they fit better ?
Post 135431 by t5tart on 2006-08-18 14:25:40
oh is it for the throttle position sensor??
Post 135432 by Bigtony on 2006-08-18 14:31:27
Hmmn..could be....the thing is the car will start but wont idle at all if you hold the revvs it props and bangs via the inlet, manifold. shyt man I was just doing a clean up job!
Post 135527 by nobananas on 2006-08-18 22:28:47
You can't mix up an injector plug with the IAC valve plug at all can you ? I did this by accident after a rushed head job on a saab 93 turbo a few weeks ago with similar results !
Post 135567 by Bigtony on 2006-08-19 00:47:07
[QUOTE=nobananas]You can't mix up an injector plug with the IAC valve plug at all can you ? I did this by accident after a rushed head job on a saab 93 turbo a few weeks ago with similar results ![/QUOTE] Injector plug? not sure if I follow you
Post 135571 by nobananas on 2006-08-19 01:11:10
No it's all right, scratch that ! Getting my motors mixed up ! A few weeks ago I rushed a head gasket job, had to pull out all the loom and when I reconnected it got one of the multi-plugs going to the one of the injectors mixed up with the multiplug going to the iac valve (same colour and type, an inch from each other) ran a bit odd I can tell you !
