LED dash light bulbs
Post 139939 by dafinchie on 2006-09-05 19:57:47
There has probably been a post about this before but does any one know which type of bulbs i would need to use to replace all my dash light bulbs with LED's. When i say all i mean the ones in the speedo head, switches, behind the PND auto box selector and cig lighter in other words everything. I've got one bulb out behind the fuel gauge so i thought while i'm at it i'll do the lot with LED's but i want to make sure i've got the right bulbs before i start.
Post 140011 by T5ER on 2006-09-05 22:58:44
Hi mate read here http://www.vpcuk.org/forums/showthread.php?t=12232&highlight=led
Post 140041 by dafinchie on 2006-09-05 23:38:57
Thanks for that T5ER. Look fairly involved, a bit more than just changing the bulbs but wow how stunning is that when its all done. I'll have to look into it abit more
Post 141626 by sdsupaintballplayer on 2006-09-11 23:47:01
Heres mine: Image
Post 141629 by Baj on 2006-09-11 23:54:06
[QUOTE=T5ER]Hi mate read here http://www.vpcuk.org/forums/showthread.php?t=12232&highlight=led[/QUOTE] Pretty useless without a decent how-to. I tried changing my dash ones before Viking did that and somewhere there was a green filter, bugger knows where. I dont have a clue how to start on the switches
Post 141643 by abdul on 2006-09-12 07:56:53
where can u get the bulbs from
Post 141645 by dafinchie on 2006-09-12 08:24:48
I've sen some for sale on ebay but don't know how good or what they are as with anything on ebay. I was thinking about pulling a few bulbs, checking size and watt's and such and popping down my local maplins. It just means taking things apart twice which i was trying to avoid.
Post 141655 by sdsupaintballplayer on 2006-09-12 09:33:50
[QUOTE=Baj]Pretty useless without a decent how-to. I tried changing my dash ones before Viking did that and somewhere there was a green filter, bugger knows where. I dont have a clue how to start on the switches[/QUOTE] Decent how to: http://volvospeed.com/vs_forum/index.php?showtopic=5153&st=0&p=47572&#entry47572 Go volvospeed. haha.
Post 141657 by sdsupaintballplayer on 2006-09-12 09:38:57
This post is just to see if my sig is working.
Post 141658 by sdsupaintballplayer on 2006-09-12 09:39:33
sweet.
Post 141660 by Azza on 2006-09-12 09:41:43
Can you not shrink it a bit so it doesn't break the width of the page ? Azza
Post 141662 by sdsupaintballplayer on 2006-09-12 09:47:04
test number two.
Post 141663 by Azza on 2006-09-12 09:47:22
Almost :) Azza
Post 141664 by sdsupaintballplayer on 2006-09-12 09:50:34
Third times a charm?
Post 141665 by Azza on 2006-09-12 10:02:32
It indeed seems so! Azza
Post 141667 by The Flying Banana on 2006-09-12 10:11:07
[QUOTE=sdsupaintballplayer]Third times a charm?[/QUOTE] And so's the car!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Post 141811 by Vikingxl on 2006-09-12 23:03:23
[QUOTE=Baj]Pretty useless without a decent how-to. I tried changing my dash ones before Viking did that and somewhere there was a green filter, bugger knows where. I dont have a clue how to start on the switches[/QUOTE] Baj what happened mate im sure you said you could do this no problem with a pack of cheap leds from halfords
Post 141852 by Justin on 2006-09-13 08:45:44
Yes Baj, did the £4.99 pack work or not ?
Post 142888 by sdsupaintballplayer on 2006-09-15 21:54:56
http://cgi.ebay.com/100pc-diffused-3mm-frosted-TINTED-DARK-BLUE-LED-COOL_W0QQitemZ150030849869QQihZ005QQcategoryZ66954QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Thats what I bought for my conversion, gave me lots of extras to try anything I want, just get 3mm LEDs cause those are the ones you use most everywhere to convert.
Post 142907 by Baj on 2006-09-15 23:32:45
[QUOTE=Justin]Yes Baj, did the £4.99 pack work or not ?[/QUOTE] Sorry, only just spotted this. First I will deal with the post immediately above: How did you find these? I looked at them but they seemed to be very dark. Right, the Halfords ones were/are fine. They take a bit of work as they are 5mm iirc and have heatshrunk wire at the bottom so you need to drill out the bulb area for the LED to fit into then drill a hole for the wire, fit it together, bend the wires etc I have just bought these: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=002&item=120031312376&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1 and a blue variant as I cant decide which to do. Blue cos it looks nice or white because it might look good too, and it will match my boost guage. I am waiting for them to arrive. Hopefully it should be a little easier (and cheaper) and they will fit in the switches. They may need sanding to diffuse, bigger resistors to turn them down a little, sanding down flat to widen the beam.
Post 142923 by sdsupaintballplayer on 2006-09-16 00:38:25
if you use white, the color will be a light blue, due to the tint on the switches. The tint combines with the yellow bulb light to make the green you see. They are not too dark, as you can see from my picture, they are pretty bright, even though that pic makes them look brighter then they are, its quite pleasent.
Post 142929 by Baj on 2006-09-16 00:55:40
The LEDs in the door switches are green with no tint. I will have a play to see what looks best. At £1.58 for 50 I dont care if half are useless :)
