Blue LED switches. A pictorial journey - Pt1
Post 144902 by Baj on 2006-09-21 22:49:22
Door window switches Tools needed: Wire cutters small flat screwdriver Heatshrink or electrical insulation tape 3mm LEDs Soldering iron (Some thin guage wire may be handy if you get stuck) A V70 or similar Step 0: Order some LEDs I bought 50 from a nice man in Hong Kong for £1.58 plus a few quid P&P. Makes Maplins £2.50 for 2 seem a bit expensive. Mine are 13000 thingies in brightness which in retrospect may be a little too bright. They are 3.5v but come with 50 resistors for 12v use. Dont try them without the resistor, the smell is nasty! Step 1: Take apart the door switch Image We are working with the passenger door switch here (more space to practice with). Using a small flat screwdriver gently pry up the cover over the catches (circled), starting from one end and working round. Step 2: The green LEDs Image Here are the buggers on their little black towers. Step 3: Cut the LEDs off Image Cut off the window switch LED about halfway. Image Cut off the lock LED near to the top. Unless you have a long, thin soldering iron it will be hard to solder the wires if they are too short. Step 4: Its solder time (switch LED) Image Solder the resistor to the LED. Marvel at my great soldering and my high-tech solder mat. When doing the drivers side you may want to plan the length of the wires as the space is very limited but here you have room to move things about a bit. Image Place the LED at the top of the tower moulding, curve the wires down and solder to the old LED wires. Cut off the excess wire. Fold the resistor out the way and insulate with heatshrink or bodge-tape. (circled) Ensure the wires will not touch the window switch components. Image Bung some heatshrink over the LED and wires (putting the heatshrink on first may help hold the LED in place) Step 5: Its solder time (lock LED) Image Positioning the resistor is a little tricky here as the switch for the locks runs over the front and back of the LED. Stick it to one side, again insulating it with heatshrink. It is worth noting at this point that you check the polarity before soldering so you dont have to unsolder & resolder (voice of experience :) ) Step 6: Finished Image Reassemble and marvel. Epilogue: There is some reflected glow under the switch. This is mainly due to the intensity of the LEDs chosen combined with the white underside of the switch. I may fix this. For the drivers door switches you can tuck the resistor behind the LED pillar as the casing is slightly raised. If you get LEDs with a rim at the base you may need to either sand off the rim or cut off the small tubes that are under the switch button (not pictured as they arent on the passenger side [I did the drivers side first and didnt photograph it]) Next week: Dash switch lights (once I work out why the ones I have done are shorting out the stereo!)
Post 144910 by BlackBeast on 2006-09-21 23:10:36
Get one with it :)
Post 144912 by Baj on 2006-09-21 23:13:37
Get one what with what, good sir?
Post 144915 by BlackBeast on 2006-09-21 23:25:44
Part 2, 3, 4 and 5 :)
Post 144917 by Justin on 2006-09-21 23:27:31
I think I'm gonna change your name from Baj to Boj lol
Post 144920 by Baj on 2006-09-21 23:35:27
Please yourselves
Post 144921 by thunderace on 2006-09-21 23:44:43
nice one Baj :)
Post 144936 by abdul on 2006-09-22 08:07:13
excelent can we have a contact for suplier
Post 144960 by Al115 on 2006-09-22 10:37:10
Useful - and I particularly liked the commentary :)
Post 144988 by Baj on 2006-09-22 13:51:56
[QUOTE=abdul]excelent can we have a contact for suplier[/QUOTE] http://stores.ebay.co.uk/Light-of-Victory-Led-Store-lvehk_W0QQsspagenameZL2QQtZkm Ordered Thursday, arrived Tuesday
Post 145013 by BrightonBreezy on 2006-09-22 15:32:00
Excellent pictorial how-to. Well done. I might have a go at that.
Post 145017 by Baj on 2006-09-22 15:43:21
I accept no liability for damage to switches and or electrical systems due to dodgy soldering, resistance etc :D
Post 145033 by muscas on 2006-09-22 16:41:46
Brilliant, thanks for all your efforts, great photos!
Post 145076 by abdul on 2006-09-22 18:39:08
Thanks For Contact
Post 145091 by dicky b t5 on 2006-09-22 19:02:12
Great " How to Baj " ..Cheap as well......Nice.:Handshake
Post 145151 by Vikingxl on 2006-09-23 09:42:08
Baj you should be able to still use the dimmer control if you feel they are too bright mate
Post 145177 by Baj on 2006-09-23 12:17:46
Yeah, the dimmer will work on the dash but it wont work on the window switches.
Post 149427 by RPM on 2006-10-07 09:27:26
any update on your dash?
