Post 14036 by markt4 on 2005-04-10 17:27:18
think mine is knackerd , ive tried to take it apart but it wont , ive buggerd the little screws on it :doh: its made by forge , so can i replace it with any d/v as a straight swap? whats the best one to get and where from
cheers in advance
Post 14040 by fraz13 on 2005-04-10 17:35:17
You should be able to replace a forge at Half*rds, making sure its a double piston DV, other than that most performance places will be able to supply, piston are usually better than diaphram DV's
Post 14044 by Ross9 on 2005-04-10 17:45:59
I take it this has turned out to be the problem with your T4 feeling a bit flat? Losing boost through a leaky dump valve?
Ross
Post 14045 by siamblue on 2005-04-10 17:47:25
You can get them on Ebay for about £90 with the Silicone hose for the I/C.
Post 14051 by rich850t5 on 2005-04-10 18:23:46
[QUOTE=siamblue]You can get them on Ebay for about £90 with the Silicone hose for the I/C.[/QUOTE]If you are on about the bailey d/v then they are £100 delivered i got one and it seems ok fairly noisey when boost is around 12/15psi
Post 14055 by markt4 on 2005-04-10 18:27:51
well ross that was my next question , would a dodgy d/v affect performance???remember i am braindead with engines , ive looked on ebay and there are that many...any recommendations theres baily, blitz,hks, greedy and others (others r alot cheeper, but cheap aint allways the best, as the saying goes buy cheap buy twice.)
Post 14121 by Ross9 on 2005-04-10 23:39:47
Yes it would affect it.
When you have your foot down, the turbo spins and forces air along a pipe, through the intercooler, along another pipe and into the engine, aftermarket DV's are normally fitted to the second pipe, from the IC to the throttle body, anyway, the dv's job is to be closed when on throttle, and open when you let off, thus venting the compressed air in the pipe.
If it isn't closed when you are on throttle, then air (boost) will leak out of the DV and not all go into the intake, you wont make as much boost as you should be doing, and the car will be slower.
So if your DV is being changed because its leaking, then fingers crossed it will sort your other problem as well, so heres hoping.
Ross
Post 14130 by siamblue on 2005-04-11 00:49:37
Quite a few people that go for D/Vs go for the Forge twin piston type.
Post 14229 by Bracer on 2005-04-11 11:47:37
I prefer the adjustable types as you can fine tune them.
Post 14231 by siamblue on 2005-04-11 11:50:36
[QUOTE=Bracer]I prefer the adjustable types as you can fine tune them.[/QUOTE]
Come on then Steve why and how please? :shockedbi :deal:
Post 14232 by Bracer on 2005-04-11 11:53:00
[QUOTE=siamblue]Come on then Steve why and how please? :shockedbi :deal:[/QUOTE]
My Turbo XS valve allows you to add / remove shims which pretension the spring controlling the vac pressure and release boost setting.
Post 14412 by markt4 on 2005-04-11 19:34:08
thanks for the info all , well appreciated
Post 14414 by rich850t5 on 2005-04-11 19:40:17
[QUOTE=Bracer]My Turbo XS valve allows you to add / remove shims which pretension the spring controlling the vac pressure and release boost setting.[/QUOTE]Steve will my bailey d/v be ok everything seems ok but what would the symptoms be? cheers kind chappy! :thewave:
Post 14571 by Bracer on 2005-04-12 08:32:59
[QUOTE=rich850t5]Steve will my bailey d/v be ok everything seems ok but what would the symptoms be? cheers kind chappy! :thewave:[/QUOTE]
It should be ok.
