Post 149097 by richeeroo on 2006-10-06 07:40:22
Hi Everybody !!!
I have an intermittent fault with the ABS / Tracs light coming on on my V70. Can i do a straight swop with the module off my 850 as i know this works fine.This will hopefully solve the problem and also eliminate any wheel sensor problems and then i can take it from there. Any help would be great, thanks all, Rich.
Post 149122 by Vikingxl on 2006-10-06 10:07:14
No idea if you ncan swap but Vt do a repair service i think
Post 149245 by Wobbly Dave on 2006-10-06 17:19:07
[QUOTE=richeeroo]Hi Everybody !!!
I have an intermittent fault with the ABS / Tracs light coming on on my V70. Can i do a straight swop with the module off my 850 as i know this works fine.This will hopefully solve the problem and also eliminate any wheel sensor problems and then i can take it from there. Any help would be great, thanks all, Rich.[/QUOTE]
I do a repair service through VT. 12 month warranty on my repair work. Please read...
http://www.vpcuk.org/forums/t224-abs-ecu-repair-service.html
