SC805 button illumination
Post 156719 by paullus on 2006-10-29 14:09:03
I think a couple of bulbs in my SC805 have blown because not all of the radio preset buttons and other buttons are lit. Are the bulbs available and easy to replace? Cheers,
Post 156731 by neevo on 2006-10-29 16:10:07
You need to wait for VikingT5 or Baj to come on as they are well up on the various bulbs around the dash etc. Meanwhile, bump ;)
Post 156751 by Vikingxl on 2006-10-29 16:57:14
Can be done no problem takes about five mins!
Post 156776 by paullus on 2006-10-29 18:15:45
Nice to hear. Nothing complicated then. Just take of the fascia panel and put new bulbs in? Are the bulbs anything special? Cheers.
Post 156843 by Vikingxl on 2006-10-29 20:33:47
Bulbs may be a little tricky try volvo and if not take one out and take it to your local honda dealer as i have been told they do them.Pm me with your phone number and i will give you a ring witha few tips!
Post 157095 by paullus on 2006-10-30 18:51:08
Hi VikingT5 Got a bulb out this evening without too much trouble. Little blue rubbery(?!) LED thingy on a black plastic base. I'm going to Volvo tomorrow to swap the washer jets they incorrectly supplied so I'll ask about the bulbs and then Honda if no luck. Are these bulbs used anywhere else on the car or is it just the radio? Thanks very much.
Post 157107 by Vikingxl on 2006-10-30 19:05:56
Not with the blue sleeve on them mate and be warned they aint gonna be cheap!
Post 157132 by gibbo on 2006-10-30 19:32:43
[QUOTE=paullus]I think a couple of bulbs in my SC805 have blown because not all of the radio preset buttons and other buttons are lit. Are the bulbs available and easy to replace? Cheers,[/QUOTE] How many buttons are illuminated mate? Only the 1,2,3 buttons light up on mine when the lights are on? Gibbo
Post 157294 by paullus on 2006-10-31 07:26:41
Hi Gibbo 4, 5 & 6 on mine. Now I've had the front off I know why. There are only 4 or 5 bulbs to illuminate all the buttons and controls. The light is distributed from the bulbs to the controlls by clear plastic light tubes/fibre optics. Basically 1 bulb lights up several different things. I'll let you know how I go on at Volvo. Cheers.
Post 158164 by paullus on 2006-11-02 21:36:35
Repaired it tonight and it all lights up as it should. Bought 4x PG80 12v Submin blue bulbs from Maplin for £1.96. Very carefully unpicked the old bulbs from the plastic base, reffitted the new ones and carefully rewound the wire tails. I then used a blob of superglue to ensure the wires don't unwind. Fiddly job but worth it.
Post 158179 by Vikingxl on 2006-11-02 21:49:45
Nice one mate hows the colour match?
Post 158298 by paullus on 2006-11-03 07:17:09
Not a bad match. The Maplin blue is darker than the originals with the blue sleeve but at least I can see the buttons now. I might replace the other two originals to make them all the same . Alternatively I could buy some white bulbs and use the original sleeves on them. They'll do for the time being though.
Post 158353 by paullus on 2006-11-03 18:27:19
I parked the car in the garage tonight and had a play with the dash illumination rheostat and I've decided I prefer the Maplin blues. So the radio comes out again tomorrow so I can do the rest.
