Boost Gauge Fitting 850
Post 164717 by dazat5 on 2008-07-08 14:24:55
Hi all just wondering whats the best way too fit a boost gauge to my 850, i want the gauge in the same place as where the info switch is, the gauge fits nice in there, but my problem is where do i come into the car from the engine with the pipe? Cheers
Post 164750 by Alan M on 2008-07-08 15:51:12
Under the dash to the right. You will need to tee into the hose for the dash gauge and run your new hose up through the steering column and through the underside of the plstic where you want the gauge. Not so much the steering column but above it.
Post 164756 by T5-TEZ on 2008-07-08 15:54:51
You could also take a feed straight from the vacuum tree saves inserting a T piece.
Post 164757 by dazat5 on 2008-07-08 15:55:26
thanx alan :Handshake
Post 164758 by dazat5 on 2008-07-08 15:56:10
[QUOTE=T5-TEZ;164756]You could also take a feed straight from the vacuum tree saves inserting a T piece.[/QUOTE] Yes i think ill do that one, thats the tree under the throttle cover right?
Post 164759 by T5-TEZ on 2008-07-08 15:58:13
[QUOTE=dazat5;164758]Yes i think ill do that one, thats the tree under the throttle cover right?[/QUOTE] Yes mate thats the one.
Post 164764 by dazat5 on 2008-07-08 16:03:20
right ok thats sorted then, just need to find a route from the tree to where my gauge is going
Post 164826 by brett craig on 2008-07-08 19:18:43
ran mine from under the dash and found it inacurate, go for the vac tree but from a rear port as you tend to kink the hose under the cover if you go from the front
Post 164831 by CONDYBOY on 2008-07-08 19:27:39
Are you doing away with the info switch? See my thread in the s/v40 forum called v40 mods for another idea!:D
Post 164851 by T5-TEZ on 2008-07-08 20:11:37
[QUOTE=dazat5;164764]right ok thats sorted then, just need to find a route from the tree to where my gauge is going[/QUOTE] I ran mine through the gromet hole where the loom goes through the bulkhead if that helps.
Post 164925 by nobananas on 2008-07-08 22:48:56
Here's mine (deja -vu !) Image
Post 164971 by dazat5 on 2008-07-09 09:18:25
[QUOTE=nobananas;164925]Here's mine (deja -vu !) Image[/QUOTE] Thats a good way of doing it, looks pretty tidy, anyway i got mine plumbed in, i just cant find the wires to hook up for the illumination, i got told connect the gauge wires to the pink and black.. i did that and nothing
Post 164988 by Alan M on 2008-07-09 10:22:44
Because the gauge don't draw much current I took my supply from the stereo ignition live and ground. HTH.
Post 165117 by brett craig on 2008-07-09 20:35:33
took mine from the sidelight wires on the back of the main switch
