Post 166527 by CONDYBOY on 2008-07-14 11:28:51
Okay after a hint from bradley and T5-TEZ (Thanks for the tips guys) on this site i used a heat gun on the black trim panels that the headlamp wiper spindles poke though to bring them back to black. And it works as long as you keep the heat gun moving so as to not melt the trims and watch for the oils coming to the surface you will be okay, it's the oils that give the colour back. see pics for what it looks like!:D:)
Post 166528 by jonno12 on 2008-07-14 11:32:37
can you do this on the door trims aswell?
Post 166537 by wegal on 2008-07-14 12:02:21
You can do it on any plastic trim so long as its thermoplastic and not thermosetting, generally soft plastics are thermoplastic and hard plastics are thermosetting. However i have done this to my works volvo and im afraid that the effect is temperary, the oils will wash away with a combination of road salt and detergents.
Post 166794 by AndyJudge on 2008-07-14 22:54:17
Saw a Top tip on restoring trim on one Sat channels the other day. Apparently Smooth peanut butter does the Biz as well, rumour has it that it lasts longer than back to black as well.
Must say though I've not tried it yet
Andy
Post 166796 by t5 stealth on 2008-07-14 23:18:10
i think it was the oil on the surface of peanut butter,not the peanut butter.
i saw something about it somewhere aswell.looked good but i think it will only be a temp fix
Post 166854 by T5-TEZ on 2008-07-15 09:50:45
[QUOTE=CONDYBOY;166527]Okay after a hint from bradley and T5-TEZ (Thanks for the tips guys) on this site i used a heat gun on the black trim panels that the headlamp wiper spindles poke though to bring them back to black. And it works as long as you keep the heat gun moving so as to not melt the trims and watch for the oils coming to the surface you will be okay, it's the oils that give the colour back. see pics for what it looks like!:D:)[/QUOTE]
Glad you got it sorted mate,it makes such a differance doesnt it.
If you apply a good plastic trim treatment on them they sould last longer.
Post 166865 by cameron on 2008-07-15 10:14:43
May seem a bit of a cowboy job, but i use Wax shoe polish, you know the liquid type, the one with the sponge on the top, cost - 85p, does the whole car about 10 times and lasts about 3 months each time, good cheap alternative to back to black which i dont rate at all.
See the proof for yourself, lovely deep black !!!!!
http://www.vpcuk.org/forums/showthread.php?t=15976
Post 166871 by T5-TEZ on 2008-07-15 10:31:21
[QUOTE=cameron793;166865]May seem a bit of a cowboy job, but i use Wax shoe polish, you know the liquid type, the one with the sponge on the top, cost - 85p, does the whole car about 10 times and lasts about 3 months each time, good cheap alternative to back to black which i dont rate at all.
http://www.vpcuk.org/forums/showthread.php?t=15976[/QUOTE]
I use the Kiwi black shoe liquid wax for my door handles and it works a treat and like you said lasts 3 times longer than back to black.
Post 166923 by RobbieH on 2008-07-15 14:06:40
[QUOTE=T5-TEZ;166871]I use the Kiwi black shoe liquid wax for my door handles and it works a treat and like you said lasts 3 times longer than back to black.[/QUOTE]
Morrisons own liquid shoe polish. I use it to cover up if I go a bit overboard with polish and wax and get it on the trims.:doh:
Post 166925 by cameron on 2008-07-15 14:12:01
[QUOTE=RobbieH;166923]Morrisons own liquid shoe polish. I use it to cover up if I go a bit overboard with polish and wax and get it on the trims.:doh:[/QUOTE]
Thats the one i use Robbie, not bad eh?
Post 166986 by RobbieH on 2008-07-15 18:19:26
Does the job. Not quite what it says on the tin......... :B_thumb:
Have to be careful not to get it on the paintwork else it's quite hard to remove (like getting polish/wax on the plastic). Am I going round in circles here?:rolling_e
Post 187406 by CONDYBOY on 2008-10-09 21:53:17
Heat gun only lasted about two weeks then back to grey!
might just paint them the same colour as the body.
Post 189765 by cuda67 on 2008-10-20 23:39:21
wouldnt admit to it in the pub, but i use baby oil. works great and lasts 3-5 months, ssshhh dont tell anyone!
Post 189801 by LesRED850R on 2008-10-21 03:12:22
[quote=cuda67;189765]wouldnt admit to it in the pub, but i use baby oil. works great and lasts 3-5 months, ssshhh dont tell anyone![/quote]
Mmmmmm , now if you use the peanut butter on one part and the shoe polish on others and the BB/oil as well you are set for a night out ! Food , grooming and some lube..............:crazy:
Post 189883 by cookie on 2008-10-21 14:05:04
For permenant black results then only product I have found that works is
Forever Black
Have some pics of ellas old clio, and trim went from grey with white spots and marks, to an almost new black (has a very slight sheen, but not a orrible glossy/shiny finish)
If I can dig oot pics I will upload them
Post 190217 by nobananas on 2008-10-22 20:27:06
Mat of mine used to swear by DBO for his black trim. (that's dirty black oil if you were wondering !)
