Post 182940 by Murphy on 2008-09-19 14:39:34
Hi
A collegue at work has a P2 V70 with a fooked CD player. So what are the options?
He has found one on ebay, a HU803. Is it a direct replacement or does he need to stick to the 603. Also, is ebay a good bet, or is somewhere like salvo better??
Any advice appreciated.
Cheers
Andrew
Post 182949 by S60-MBS on 2008-09-19 15:19:23
Ebay you vcan get some bargains,your mate needs to be careful as some Headunits are mated to car chassis,The 603 is non software driven so can go into anything.
Post 183072 by thebadger on 2008-09-20 02:01:06
Go aftermarket, the output is much better, also you can look to do a sub install with one.
Post 183088 by saufboy on 2008-09-20 09:46:01
[quote=Murphy;182940]Hi
Cheers
Andrew[/quote]
If i remember correctly if you go to the main dealer you can do an exchange for around £100, check it out as i am not sure??
Post 183114 by Baj on 2008-09-20 15:03:04
I can do him a carPc for significant money :)
Post 183116 by D5 Stunt Man on 2008-09-20 16:34:11
[quote=saufboy;183088]If i remember correctly if you go to the main dealer you can do an exchange for around £100, check it out as i am not sure??[/quote]
Not any more.
I looked into this recently and you are now looking at £500ish.
Pick a HU-803 up on Ebay, theres tons of them.
Post 183120 by mhon72 on 2008-09-20 16:55:40
[quote=Murphy;182940]He has found one on ebay, a HU803. Is it a direct replacement or does he need to stick to the 603. Also, is ebay a good bet, or is somewhere like salvo better??[/quote]
The HU-803 needs the external amp to feed the speakers.
It only has a small internal one for the Dolby centre speaker in the dash.
Post 183128 by saufboy on 2008-09-20 19:23:01
[quote=D5 Stunt Man;183116]Not any more.
Pick a HU-803 up on Ebay, theres tons of them.[/quote]
I am pretty sure the 803 is car specific so your better off with another 603, it could cost you a fair few quid at the dealer to program the 803 in aswell.
Post 183426 by Murphy on 2008-09-22 13:02:52
So, the 803 is out. After market is not a route he wants to go - so 603 from Salvo maybe?
Post 183508 by saufboy on 2008-09-22 19:13:39
[quote=Murphy;183426]So, the 803 is out. After market is not a route he wants to go - so 603 from Salvo maybe?[/quote]
Try Adam (readview) i am pretty sure he might have some knocking about in the cupboard.
