water loss
Post 191442 by abdul on 2008-10-26 19:06:47
car is loosing water and theres a bad smell inside the car i thought it is the heater matrix but i have no water on the passenger side carpet any advise thanks
Post 191464 by pangster on 2008-10-26 19:44:46
[quote=abdul;191442]car is loosing water and theres a bad smell inside the car i thought it is the heater matrix but i have no water on the passenger side carpet any advise thanks[/quote] have you lifted the carpet up? as the carpet is rubber backed and it won't soak through easily..
Post 191467 by abdul on 2008-10-26 19:46:48
will lift the carpet to check thanks
Post 191469 by mike k on 2008-10-26 19:47:13
its not dripping out of the air con drain is it? ________ Roll blunts
Post 191471 by abdul on 2008-10-26 19:48:31
[quote=mike k;191469]its not dripping out of the air con drain is it?[/quote] where is that located
Post 192573 by abdul on 2008-10-31 18:35:50
is there a how to change the heater matrix
Post 192584 by Tomcat on 2008-10-31 18:43:41
There was, not sure it's still here though after the big crash.
Post 192626 by pangster on 2008-10-31 19:25:55
[quote=Tomcat;192584]There was, not sure it's still here though after the big crash.[/quote] I remember reading it on here as well.. I can't find it now though - typical! lol!.. I have found this one for the S80 on VS - which is fairly similar and will give you an idea what is involved: http://volvospeed.com/Repair/heater_core.html just remember and replace the o-rings at the same time! lol! :) HTH
