Thermostat replacement, is there a how to?
Post 192454 by Liddo on 2008-10-31 10:18:56
Hi Chaps n Chapess's Im going to do my Thermostat over the weekend, as the temp gauge keeps dropping low, then back up again to normal, then low again. It looks like its only two torx screws and out she comes, is this correct??? Ive ordered a 92c stat and rubber seal for PFV for my 1999 C70 T5 (hope thats correct too) Are there any how to's, or is it as easy as just the 2 screws??
Post 192486 by Jaseb77 on 2008-10-31 13:21:08
the torx screw are a PITA, and round easily, and are welded in due to the heat be prepared for that and the whole housing can snap off if pressure applied. sometimes better having a spare from a scrappy other than that straight forward
Post 192506 by Liddo on 2008-10-31 14:14:06
[quote=Jaseb77;192486]the torx screw are a PITA, and round easily, and are welded in due to the heat be prepared for that and the whole housing can snap off if pressure applied. sometimes better having a spare from a scrappy other than that straight forward[/quote] DOH! ok, cheers for that Jase, something to look forward to :doh:
Post 192525 by Liddo on 2008-10-31 15:24:52
[quote=Fletchv70RAWD;192517]Took me 5mins to change mine whilst I was in the chat room one night - no-one even noticed I had gone LOL[/quote] LOL, i guess your screws where loose then ;)
Post 192549 by Terminator on 2008-10-31 16:32:59
Spray generously with WD40, leave to soak, then put a 1/2 inch torque socket on an extension bar, as you can push against it (ooh matron), which minimises the risk of rounding the screws!
Post 192554 by PNuT on 2008-10-31 17:25:31
[quote=Liddo;192525]LOL, i guess your screws where loose then ;)[/quote] the important bit is getting straight on one of the bolts! if you are not straight it can cause problems..... at worst drill the head of the bolt off! that way you wont crack the housing as mentioned earlier in the thread ;)
Post 193197 by Liddo on 2008-11-03 09:16:27
Last question, is it better to have a "warm" engine?? Just thinking it may help getting the bolts out ?????
Post 193199 by Tomcat on 2008-11-03 09:37:01
I want to do mine but I'm scared to death of breaking something, I gave it an experimental try the other day but it was damn tight.
Post 193234 by Liddo on 2008-11-03 12:01:28
[quote=Tomcat;193199]I want to do mine but I'm scared to death of breaking something, I gave it an experimental try the other day but it was damn tight.[/quote] Dohhhh, dont say that! Ive got a feeling mines gonna be too :( Will let you know how it goes ;)
Post 193236 by Okete on 2008-11-03 12:16:09
Is this any use? http://www.vpcuk.org/forums/showthread.php?t=4260&highlight=Change+Thermostat
Post 193246 by Liddo on 2008-11-03 12:55:41
Ive been looking for that ;) Thanks a lot matey
Post 193247 by Okete on 2008-11-03 13:00:34
You're welcome!
Post 193354 by Liddo on 2008-11-03 21:32:22
UPDATE: All done in 5 mins tops, a total peice of p**s. Both screws/bolts undone quite easily after soaking them in WD (no, not Wobbley Dave). Old knackered thermo out, and new PFV one in, and job done. Nice steady 3 oclock gauge and no leaks :D BTW, mines the ME7 engine, so I didnt have to remove any fuel lines or anything. And I used a small, cheap torx set from ASDA :D
Post 193355 by Tomcat on 2008-11-03 21:33:25
Well done that man, glad your all sorted.
Post 193416 by Liddo on 2008-11-04 09:38:07
[quote=Tomcat;193355]Well done that man, glad your all sorted.[/quote] If ya need a hand doing your's let me know, but its DEAD easy and Im SURE you'll cope ;)
