Centre Speaker
Post 195727 by Cubes on 2008-11-14 12:02:13
Hi all. Despite my best efforts I still have an annoying vibration coming from the Pro Logic centre speaker on the dash. Has anyone out there ever removed to cover? And if so, how???
Post 195753 by thebadger on 2008-11-14 15:24:53
I took the cover off my speaker by taking out the air vents, but it's a p2 v70... Should work tho! Clips are inside the vents btw!
Post 195755 by thebadger on 2008-11-14 15:39:58
Found a good pic of what's under the grill! http://www.krypet.net/rti/hal.jpg
Post 195765 by Cubes on 2008-11-14 16:38:18
Looks like I've got some exploring to do!
Post 195779 by ctautos@btinternet.com on 2008-11-14 18:26:50
befor you take off the grill.the green connecter is not off the speaker i think it is off the back of the cd/radio need help you can call me 07771554978
Post 195860 by Cubes on 2008-11-15 00:10:21
Thanks fella. I'm not going to get the chance to have a tinker about with it now for a few days, what with birthday drinks an' all! I will have a crack at it when I sober up! In the meantime, any other suggestions are more than welcome!! Keep 'em comin...
Post 195864 by ctautos@btinternet.com on 2008-11-15 07:39:42
[quote=Cubes;195860]Thanks fella. I'm not going to get the chance to have a tinker about with it now for a few days, what with birthday drinks an' all! I will have a crack at it when I sober up! In the meantime, any other suggestions are more than welcome!! Keep 'em comin...[/quote] the easy way out is to take out the dash it is simple.the easiest i have done cheers
Post 196120 by Baj on 2008-11-17 01:35:04
On mine I needed to get the wire mesh off first. It is the same as normal speakers in that there is a groove all te way round that the mesh sits in. It has tabs which make it tricky and is almost impossible to do without bending it. Watchmakers screwdrivers helped. Again mine is a P2
Post 196127 by ctautos@btinternet.com on 2008-11-17 06:59:48
[quote=Baj;196120]On mine I needed to get the wire mesh off first. It is the same as normal speakers in that there is a groove all te way round that the mesh sits in. It has tabs which make it tricky and is almost impossible to do without bending it. Watchmakers screwdrivers helped. Again mine is a P2[/quote] hi if you look at the speaker there is no way of getting the speaker off.the only way of changing the speaker would be to remove the dash.pop in to your volvo dealer and they will advise if not i might be in manchester the end of the week hope this help"s
Post 196151 by Cubes on 2008-11-17 13:12:46
Thanks for the advice. I won't get chance to have a look at it until back end of the week but I will bare all the above in mind for when I do. I might well be back...!
Post 196153 by siamblue on 2008-11-17 13:55:25
Mine was a right cow to get off, obviously it had never been off, i thought at one point i was going to break it, Gary
Post 196234 by thebadger on 2008-11-17 22:52:20
REMOVE THE AIR VENT!!!! ps, the green socket is for an RTI system, not a stereo! I took out the centre airvent in the console & pushed the clips out from below! No broken bits!
Post 196235 by siamblue on 2008-11-17 22:56:41
Well my centre speaker and pro logic system both had a Green connector,
Post 196371 by thebadger on 2008-11-18 20:43:47
Siam, how many wires does one speaker need? It is the RTI, look at the link name... it's off an RTI how to guide i've been looking at! Thinking of going down the pop up monitor road soon! Sadly I have bought an old screen that uses that socket & not a new one which uses an easily got aftermarket one! Tsk!
