MBC on an LPT? Anyone done it?
Post 201286 by Dangerous Dave on 2008-12-13 17:09:23
Anyone fitted an mbc to a LPT volvo engine? Was it worth it? Also, what the bloody hell is the difference between a bleed valve and an mbc, becuase I keep reading different threads and now I'm more confused. The mbc's available on ebay look like bleed valves.
Post 201287 by Volvostorm on 2008-12-13 17:18:57
I thought they were similar, but I'm not keen on either, I feel they are a bit of a bodge. Sorry, I know this won't help!:wiggle:
Post 201290 by Dangerous Dave on 2008-12-13 17:29:59
Cheers, any help is better than nothing.
Post 201294 by p fandango on 2008-12-13 17:49:16
a bleed valve only drains off an adjustable amount of air, still allowing some air thru to the actuator & still allowing wastegate creep (where the wastegate starts to open before the desired limit wasting boost) a MBC blocks the air altogether creating a much more aggresive drive & alot better in my opinion as a rule a bleed valve will have 3 pipe outlets while a MBC only has 2 i've used an MBC for about 7years & wouldn't do it any other way (except an EBC i've got now lol)
