feckin alarm
Post 19755 by alan on 2005-05-09 22:40:56
my alarm has decided to go off at random over the last couple of days. i have a 99 c70. it has never done this before. if anybody has any ideas would be greatly recieved. it is just a bit annoying when you have to turn it off at 1.30am regards alan
Post 19768 by vt5 on 2005-05-09 23:36:01
Best advice is book it into a specialist and get them to check the sensors for you. My 850 alarm goe soff in hail or freezing weather where rain is pelting the windows. Also if you jet wash the drivers side window top, though the seal looks like its twisted over, but it doesnt leak. Depending on your radio, i usually disconnect the battery terminal so i know it wont go off. Sleep is great then. Ive learned to live with this now and it only happens in winter so i'll probably put this down to "character" and never get it fixed.....also cos im lazy that way.
Post 19769 by splatt on 2005-05-09 23:44:07
I had a thatcham cat 1 alarm do this,,,,they do a learning thing so let them get on wit it for a day or 2. If it continues to disturb you ...reset it....?....it will sort itself out
Post 19770 by riedquat on 2005-05-09 23:45:48
Have you got any coins in the coin box? As unbelievable as it sounds i've had coins trigger the movement sensor if I leave them in overnight (something to do with absorbsion of the emitted wave by the coin alloy) and disconnectting the battery might not work..many c70's including mine had the backup alarm battery fitted so yanking the leads doesn't work.
Post 19808 by lance on 2005-05-10 11:41:59
Make sure you have no coins in the coin slot, as this will activate the alarm as temp changes HONESTLY its happened to me on more than one occasion and even managed to flatten my battery at heathrow!
Post 19951 by alan on 2005-05-10 19:21:48
have taken the said coins out of the dash, also had swining gear in a bag in the car so took it out as thought there could be moisture from this setting it of. just had to buy a new maf sensor today. happy days at least got one for £90 Regards Alan
Post 80011 by r07s on 2006-02-12 11:23:31
Mine doesnt like the rain - im off to Phil Whittaker next sat for a £27 diagnosis which should reveal what is going down. The 1.30am alarm wake up call is no fun :slap: the 3.40 one i did in my sleep - groan!
Post 80014 by SaffronC70 on 2006-02-12 11:29:15
What have you got in the armrest box ? I took out a small screwdriver set, and after weeks of false alarms, nothing ever since ! Chris
Post 80054 by r07s on 2006-02-12 15:13:01
Loads a stuff in there! So will empty it out pronto - chrs mate!! Mind you it only seems to fecking go off when its raining - unless its a coinsidence... Will have the diag next sat anyway; so will post outcome.
Post 80571 by NugentS on 2006-02-14 15:52:15
YOu could always remove the air movement sensors in the tops of the b pillars. They just snap out and then you have to unplug them. See if that solves the problem. The alarm works without them being present. I had the same problem - replacing the sensors solved the problem - and they weren't terribly expensive (for Volvo parts) Sean
Post 80592 by r07s on 2006-02-14 17:58:53
[QUOTE=NugentS]YOu could always remove the air movement sensors in the tops of the b pillars. They just snap out and then you have to unplug them. See if that solves the problem. The alarm works without them being present. I had the same problem - replacing the sensors solved the problem - and they weren't terribly expensive (for Volvo parts) Sean[/QUOTE] Chrs Sean! Ive had it empty for 2 days now with nothing in the armrest and it has been ok (and theres been rain!). I will also try removing the sensors as i do want to keep stuff in the armrest... I'll post what happens on sat morning regarding the diagnostics.
