Wiring Diagrams needed urgently!
Post 205989 by mikouk on 2009-01-12 17:28:33
I have spent this afternoon taking my HU-803 Radio out and trying to connect an MP3 adapter into the cd changer cable. I have failed miserably. I have spliced open the cd changer cable but I don't know which cables are the left and the right. Basically what I need is a diagram of the cable that goes from the cd changer to the HU. Any Ideas?????????? Pleeeeeeeeeeeeease! I rang volvo and they said they weren't allowed to give out that info. nasty people.
Post 206142 by mikouk on 2009-01-13 13:47:04
Is there anywhere I can buy wiring diagrams from? getting desperate now.
Post 206324 by nagrom on 2009-01-14 10:03:19
I think you'll find that the cd changer carries data to the head unit and not left and right channels, you might be better off opening the head unit and connecting to the cassette heads. But I stand to be corrected
Post 206329 by mikouk on 2009-01-14 11:32:25
[quote]I think you'll find that the cd changer carries data to the head unit and not left and right channels, you might be better off opening the head unit and connecting to the cassette heads. But I stand to be corrected[/quote] Thanks mate, but mines not got a tape player. I will keep on trying though, there must be some way of connecting it. Cheers Mark
Post 206331 by nagrom on 2009-01-14 11:41:39
Have you tried the small fm transmitter route?
Post 206338 by mikouk on 2009-01-14 12:20:42
Yes I have but I get fed up with having to change the frequency every 10 miles. I just want to be able to plug in and go. I got the wiring in idea from an old thread where a user called 'dad racer' managed to do it in his P1 V70. He drew piccies and everything but the cd changer cable must be different. If anyones got any other ideas it would be great to hear them. I want to keep the cd changer working though. Cheers Mark
Post 206442 by Dangerous Dave on 2009-01-15 00:00:36
Here you go mate, see post #5 http://www.vpcuk.org/forums/showthread.php?t=19456
Post 206619 by mikouk on 2009-01-15 22:44:45
Thanks mate that will be very useful, but I am actually after a wiring diagram of the actual din cable going from the HU to the CD changer. I know I'm being awkward, I've cut the cable and seem to have one really thick blue cable. loads of tiny white cables and 1 Brown, One orange, and 1 green cable. Any ideas? Its driving me mad! Cheers for the help though Mark
Post 206631 by Dangerous Dave on 2009-01-15 23:06:00
Here's the pinout for a connector 8pin connector http://hacylon.cwru.edu/volvo_aux/plug.jpg or 6 pin connector http://www.imahi.net/pinout.PNG some more stuff here http://forums.swedespeed.com/zerothread?id=16735
Post 206646 by Baj on 2009-01-16 00:15:47
google it. There are a few diags out there but not sure what you need. This is all I have. I did have a load more before the server crash but they were all found at VOC, VS etc. Image
Post 206667 by mikouk on 2009-01-16 09:16:44
Thats great guys thanks. Definitely getting close, especially that post from the other forum. If only I could find one that relates to the colours of the cables rather than the pin numbers as from I am looking I can't tell which cable goes to which pin. I will keep searching though. Thanks again Mark
Post 206676 by kyebosh on 2009-01-16 10:02:11
Is this of any use to you? http://www.wothrline.se/hifi/headunit.htm
Post 206714 by Dangerous Dave on 2009-01-16 18:11:14
[quote=mikouk;206667]Thats great guys thanks. Definitely getting close, especially that post from the other forum. If only I could find one that relates to the colours of the cables rather than the pin numbers as from I am looking I can't tell which cable goes to which pin. I will keep searching though. Thanks again Mark[/quote] Use a multimeter to test each wire for each pin, and write it down.
Post 206715 by mikouk on 2009-01-16 18:14:18
Aha, good plan that man. However won't that mean cutting all the wires to get to the core, as there is no bloody way you could strip these small lengths mid way. It would be like shaving a flea! I will give it a go though anyway!
Post 206716 by Dangerous Dave on 2009-01-16 18:28:25
Sorry bud, thought you had already cut them. If you have the sharp test probes then you can just push them slightly into the wire to get a reading.
Post 206761 by mikouk on 2009-01-16 21:42:03
Ah yes, another good plan that man.
Post 206763 by Dangerous Dave on 2009-01-16 21:43:58
Good Luck
Post 206767 by S60-MBS on 2009-01-16 22:06:15
V70 wiring diagram link http://www.mojevolvo.pl/wiki/Strona_g%C5%82%C3%B3wna site is on Polish but you can follow it along to model diagrams
Post 207022 by mikouk on 2009-01-18 19:12:43
Thanks for that mate. Someone else sent them via PM and I have been scourering them ever since but no luck so far. I will keep looking though Cheers
Post 207080 by cookie on 2009-01-18 21:27:10
Tim did a how to on T5D5, but he didn't canabalise cables part 1 http://forums.t5d5.org/index.php?showtopic=2778&hl= Part 2 http://forums.t5d5.org/index.php?showtopic=2780&hl=
