Car mount for Asus EEE PC ?
Post 212181 by cornclose on 2009-02-07 11:05:39
Anyone ever come across a decent one ? Or actually have/use one ? There are a few I've found, but they're all ugly clunky looking things - need something nice and discrete...
Post 212224 by Enigma666 on 2009-02-07 15:19:44
Given the actual size of the Asus, you will be lucky to find anything discrete tbh. Most of them look like the mounts the police use for those monitors sadly :(
Post 212353 by cornclose on 2009-02-07 21:02:47
Thanks - thought as much. If anyone finds any that are more slimline, please shout up!
Post 212468 by Baj on 2009-02-08 16:21:12
Tried http://www.dashmount.co.uk/ ?
Post 212515 by cornclose on 2009-02-08 19:21:43
I hadn't, no. I've googled for hours and never come across that site. It seems however that they have no such holder... Thanks though!
Post 212520 by kyebosh on 2009-02-08 19:30:39
Any good? http://www.gpsforless.co.uk/product_details.php?id=14047
Post 212525 by cornclose on 2009-02-08 19:41:41
That's one of the ones I'd found before, and out of all of them, it's the most likely candidate. I wouldn't want it stuck to the windscreen though, I'd have to make some other mounting bracket to hold it lower in the passenger side (down at seat level I think). There's a pair of screw holes behind a plastic cover on the passenger side of the centre console which I think I could probably use (these are for mounting Volvo accessories). Might be worth a punt if nothing else can be found - seems cheap enough...
Post 212548 by Babybadger on 2009-02-08 21:21:31
[quote=cornclose;212525]That's one of the ones I'd found before, and out of all of them, it's the most likely candidate. I wouldn't want it stuck to the windscreen though, I'd have to make some other mounting bracket to hold it lower in the passenger side (down at seat level I think). There's a pair of screw holes behind a plastic cover on the passenger side of the centre console which I think I could probably use (these are for mounting Volvo accessories). Might be worth a punt if nothing else can be found - seems cheap enough...[/quote] Your are in the same boat as me, I want one of these mounts to mount off the back of the centre armrest, so the kids can watch a film while the bluetooth streams to the stereo and subwoofer do the audio bit :shockedbi
Post 212566 by cornclose on 2009-02-08 22:08:41
Interesting. Found this :- http://www.dsldevelopments.com Search for mounts for your car - there are numerous methods of mounting a device between the rear seats - some attach to headrests with an arm, and others mount to the centre arm rest for the rear passengers. Also, search for item number 215159 - this may well be the method required for the EEE PC or similar devices. I think I've found a neat solution...
Post 212807 by Babybadger on 2009-02-10 02:44:12
I have seen them before, am thinking of joining the two together somehow. I am going to take a punt on the holder, will let you know how it turns out. Don't go fopr their car charger though , it doesnt regulate the charge....get the OEM one from ASUS
Post 214348 by Babybadger on 2009-02-19 11:21:03
Got one, it holds the asus very snugly, but I still don't trust these window suckers. 1.1kg hanging off a sucker that is constantly being shaken is not going to last. But there is a way of modifying it by fabricating a small bracket to join this to a brodit seat/armrest mount. Will be looking into it.
Post 214609 by cornclose on 2009-02-20 13:01:43
Thanks! I wouldn't ever use a window sucker to be honest, and I already have Brodit mounts for other things in the Volvo and in my Mrs' car. I'm still considering whether I want to mount the EEE or get some other external monitor with a touchscreen linked to the EEE (and have the EEE mounted under the seat or something...) Sounds like the mount is good then - I think I'll order one as a temporary solution.
Post 214911 by cornclose on 2009-02-21 20:52:30
Just for confirmation, which one exactly did you get ?
Post 218607 by Babybadger on 2009-03-17 11:35:19
http://www.ultimate-netbook.co.uk/Asus/Asus-Eee-PC-1000-1000H/Asus-Eee-PC-1000-1000H-Car-Kits/Asus-Eee-PC-1000-Rigid-Car-kit___471.htm
Post 218608 by cornclose on 2009-03-17 11:47:15
Ah, that one. Ok, I've gone for the Brodit Proclip/UMPC slot mount system from DSL Developments. It hasn't arrived yet (they had to order it in specially) but I will report when I have it and have used it...
Post 218615 by Babybadger on 2009-03-17 12:43:20
[quote=cornclose;218608]Ah, that one. Ok, I've gone for the Brodit Proclip/UMPC slot mount system from DSL Developments. It hasn't arrived yet (they had to order it in specially) but I will report when I have it and have used it...[/quote] Which one did you get?
Post 218618 by cornclose on 2009-03-17 13:02:40
[quote=Babybadger;218615]Which one did you get?[/quote] This one (a quick release V-Slot mechanism designed for UMPC and TabletPC)... Image mounted onto this... Image possibly with a swivle base between them... Image (not sure if I'll need the swivle base but ordered it anyway...)
Post 218676 by Babybadger on 2009-03-17 18:12:03
[quote=cornclose;218618]This one (a quick release V-Slot mechanism designed for UMPC and TabletPC)... Image mounted onto this... Image possibly with a swivle base between them... Image (not sure if I'll need the swivle base but ordered it anyway...)[/quote] Will it take over a kilo in weight?
Post 218683 by cornclose on 2009-03-17 19:02:24
[quote=Babybadger;218676]Will it take over a kilo in weight?[/quote] Apparently, yes. I spoke at length with the supplier asking about weight and vibration (not that vibration would be a problem as mine has a solid state drive) etc, and the strength of the adhesive pad, and they said that for an eeepc it would p*ss it. When I get them, I'll mount and let you know.
Post 222715 by cornclose on 2009-04-09 17:50:35
It works very well indeed - holds the EEEPC rock solid, and the mounting position is spot on. I'll post pics when I've taken some...
Post 223998 by Babybadger on 2009-04-16 11:20:06
I must admit , mine is slightly weird at holding the asus 1000 eeepc , and I have not had it working 100% how did you mount the eeepc in the cradle?
Post 224012 by cornclose on 2009-04-16 12:29:59
[quote=Babybadger;223998]how did you mount the eeepc in the cradle?[/quote] It doesn't have a cradle as such. It uses the V-slot mechanism shown in the pictures above. It's a little difficult to visualize, I'll get some pics asap.
Post 224014 by Al115 on 2009-04-16 12:57:36
Interested to see how this works out, might try to get my EEE into my T4...
Post 224620 by Babybadger on 2009-04-20 11:15:16
My solution will be :- Asus EEEpc 1000 in holder, streaming music via bluetooth to Sony MEX-BT3600U (awesome) especially with films now with sub in the boot) Nokia N95 linked via wifi over Joikuspot lite or bluetooth over Nokia PC suite Holox BT-541 GPS bluetooth linked to N05 over bluetooth (good cold start times)
Post 224625 by cornclose on 2009-04-20 12:14:37
My solution is similar in some ways. It is :- Asus eeepc 900 (WinXP/1GB/16GB SSD) Mounted using Brodit mounts 12v Power Adapter permenantly cabled USB hub on right angled USB cable (located under driver's side dash/footwell) Connected to the USB hub are; 1. USB Sound card (connected to which is an FM transmitter for audio from the eeepc through the car's sound system) 2. USB memory stick (16GB, for audio storage) 3. OBDII interface (ELM327) for realtime dash/gauges and diagnostics The eeepc also has an 8GB SD card for additional storage, in addition to the onboard 16GB SSD (1x4GB and 1x12GB). I'm developing my own front end software to control it all at the moment. So far it's pretty neat, quick release and looks/sounds great. I'll also be creating an 'in-car' ad-hoc WiFi network with an iPhone 3G, so as to use the iPhone's internet/data features and allow the eeepc to be 'online' when required (for traffic/weather/satnav/browsing/email etc). Toying with the idea of a touchscreen conversion for the eeepc, but at present my own software uses a three button system for navigation and selection. Any key down the left-hand side of the keyboard is 'previous', any key down the right-hand side is 'next' and any key along the bottom row of the keyboard (in line with the space bar etc) is 'select'. This way it's easy to navigate around without taking your eyes off the road and without worrying about which key you're pressing. I'll post pics and progress updates as and when, perhaps starting a new thread. So far though, it's the neatest and most functional quick release CarPC system I've seen.
Post 224626 by Al115 on 2009-04-20 12:19:33
A quick-release car pc system is just what the world has been waiting for (IMHO) :D Interested in why you chose a USB soundcard for the eee. Was it because the onboard sound is sh*te? I made a (permamently-fitted) version of this about four years ago - everything tucked away under floor panels / in glove box - when the very idea of "mobile broadband" was a distant hope!!! :) :) :)
Post 224627 by cornclose on 2009-04-20 12:22:41
[quote=Al115;224626]Interested in why you chose a USB soundcard for the eee. Was it because the onboard sound is sh*te?[/quote] No, it was simply because I only wanted to connect/disconnect two cables when mounting/unmounting it. Any more than that and it becomes a pain. Everything is on the USB hub which sits below the steering column, above the footwell under the lower cover. So the only two cables to connect are a single USB cable and power (no 3.5mm audio, no USB memory sticks poking out the side etc...). :wavey:
Post 224636 by Baj on 2009-04-20 13:29:32
The trouble with a system like this is you have to remove it when you leave the car. A built in system like mine is unnickable in normal circumstances (a thief would need a good hour alone to get my screen out). Hardwired power will cause problems too. Look at something like an M2ATX or M3ATX. They have preset shutdown capabilities. An EEE is a little underpowered especially if you want to add satnav capabilities. I am running an Intel D201GLY2 but most people now are buying Dual Atom boards. They are pretty cheap. Corny, have you had a look at freeice? It is a free frontend for carpcs. Saying that it may run like a dog on the EEEs as it is Flash based. I am interested to see pics.
Post 224643 by cornclose on 2009-04-20 13:55:16
Removing it from the car is no trouble as I actually wanted something that I could remove, as I didn't want to go to the trouble of a permenantly installed system. Plus, it allows me to take out the eee for meetings etc, and generally have it with me wherever I go. Only two cables to connect/disconnect and a slot mount system makes it a breeze... Hardwiring of the power to the eee is not full-time power, only when the key is in the accessory position. I have already written code to auto-detect whether the system is running on internal batteries or not so that I can do various things. There are tools out there already that do this but none of them did exactly what I wanted, so like most things I ended up writing my own. I havn't looked at freeice, but I will, thanks. Most of the others though (centrafuse, roadrunner etc) didn't do what I wanted in the way I wanted it to, so again, rather than write plugins I decided to write my own. I'll post pics as soon as I take some!
Post 224706 by Babybadger on 2009-04-20 20:01:15
[quote=cornclose;224627]No, it was simply because I only wanted to connect/disconnect two cables when mounting/unmounting it. Any more than that and it becomes a pain. Everything is on the USB hub which sits below the steering column, above the footwell under the lower cover. So the only two cables to connect are a single USB cable and power (no 3.5mm audio, no USB memory sticks poking out the side etc...). :wavey:[/quote] How are you running the power by the way? Is it a genuine asus adapter or a chinese jobby?
Post 224720 by Baj on 2009-04-20 20:27:20
I have to say the power issue is concerning me too. Taking 12v straight from the car is not a good plan as it is not 12v and unregulated which means you can fry the PC. Running a 12v powerblock through an invertor isn't a particulary great option either.
Post 224727 by cornclose on 2009-04-20 20:56:27
Calm down calm down! It's an Asus car adapter - I never said it was connected straight to the 12v system unregulated! All I've done is removed the cigarette lighter plug and hard wired that into the aux/accessory line via a inline fuse.
Post 224766 by Babybadger on 2009-04-21 10:11:11
[quote=cornclose;224727]Calm down calm down! It's an Asus car adapter - I never said it was connected straight to the 12v system unregulated! All I've done is removed the cigarette lighter plug and hard wired that into the aux/accessory line via a inline fuse.[/quote] Linky to asus adapter?
Post 224793 by Baj on 2009-04-21 13:16:11
Fine fine, just warning that the 12v form a car is unregulated and can vary from 8v to over 14v which can cause problems or even damage.
Post 224811 by cornclose on 2009-04-21 15:51:50
I got mine from amazon, it's the same as this one :- [ame]http://www.amazon.co.uk/Car-Charger-Asus-Mini-Laptop/dp/B001GCFFZ6/ref=sr_1_4?ie=UTF8&s=electronics&qid=1240325317&sr=1-4[/ame] Mine is an Asus adapter, the one above might not be, but it looks the same. It takes input voltages from 8-30v and puts out 12v at 3.5A max.
Post 225761 by cornclose on 2009-04-27 13:39:50
I was out in the car yesterday and changing the brightness of the eee's screen became a bit of a pain. In bright sunlight I had to max it out. At night, it needs to be at it's lowest brightness. So, I had an idea, and a few hours later I have a working program that takes a snapshot image every so often from the inbuilt webcam, calculates the average light level from it, then adjusts the eee's backlight accordingly - an auto brightness control! It works really well!
Post 225792 by Al115 on 2009-04-27 15:15:20
Share share share please? :)
Post 225812 by Baj on 2009-04-27 18:39:18
You love the over-engineer dont you? :D I have an autodimming screen which uses a lightsensor. Sunlight will always be a problem on LCD screens unless you get a TMR or transflective screen such as these http://linitx.com/viewcategory.php?catid=1004 They bounce the sunlight back through the screen.
Post 225935 by cornclose on 2009-04-28 12:50:28
Yeah, I like to make use of what I've got rather than buying stuff I don't really need - where's the fun in that ? :wavey:
Post 225936 by cornclose on 2009-04-28 12:51:06
[quote=Al115;225792]Share share share please? :)[/quote] I will - drop me an email and I'll send it along - totally unsupported of course!
