Powerflex Front Upper Bulkhead Mount - Just Fitted
Post 213057 by Big Pete on 2009-02-11 18:05:28
Just to let you all know, just been out an fitted the new Powerflex Front Upper Bulkhead Mount on my 850R. Haven't seen anyone write about this on here yet so thought some people would be interested.......... I already have the Powerflex Front Upper Engine Mount so made perfect sense to get the bulkhead mount as this seemed the weak link. First impressions of the bush, its yellow and well its a LOT bigger than the stock bulkhead bush in diameter so won't fit!!! I was a bit confused by this as it says it fits petrol models only, so I contacted the great guys at RT Mechanics seeing as they had worked with Powerflex to produce this. Found out that Volvo replaced the bulkhead mount as the original one failed, luckily RT had some in stock and only about £20 so ordered one up. So it is more likely if you upgrade you will need to do the same. Once I got the new bulkhead mount found it a LOT better produced and so put it in a press to remove the original rubber bush, as always a complete pain, and I have to say even harder to remove than the OEM top engine mount bush. Once removed I cut out the rubber still left inside the bulkhead mount and inserted the new bush, no modification needed to the bush unlike I had to do on the Powerflex top engine mount when fitting that. (Picture of the 2 attached, the new bulkhead mount has the OEM bush removed) To remove the bulkhead mount from the car you need to remove the plastic shield below the window, not completely but just enough to get your ratchet and hand inside, that hides all the electric's for the wipers. I then loosened the nuts so the mount started to move downwards, I then removed nut and bolt from the upper engine mount and vertically pulled up the bracket over the top of the engine mount. I then remove the nuts that hold the bulkhead mount and it all came out. I noticed when loosening the bolt that hold the bulkhead mount in place onto the bracket that the OEM bush was rather worn. I then swopped them and put everything back together on the car. (Photo's attached) I started the engine and straight away sounded louder from the outside of the car, weird. I took the car for a spin and as soon as I got into the car there was more noise, I put it into Drive (Auto box) and the whole dash started to vibrate quite a bit (was always quiet before), but once moving it all seems pretty normal. I have to say it really feels like it has transformed the car, I even thought it felt like the car had more responsiveness and everything felt tighter. For me it is a great performance upgrade, but for many Volvo owners the extra noise may not be so welcome.
Post 213088 by AndysR on 2009-02-11 20:14:22
Russ has fitted one to mine but I have yet to collect the car, not sure about the dash rattle but certainly looking forward to hearing the difference! :)
Post 213096 by Niles on 2009-02-11 20:46:53
for the £20 do you get the Bush & the metal round bracket bit or just the bush?
Post 213097 by Mental Wealth Doctor on 2009-02-11 20:57:33
[quote=Big Pete;213057]Just to let you all know, just been out an fitted the new Powerflex Front Upper Bulkhead Mount on my 850R. Haven't seen anyone write about this on here yet so thought some people would be interested.......... I already have the Powerflex Front Upper Engine Mount so made perfect sense to get the bulkhead mount as this seemed the weak link. First impressions of the bush, its yellow and well its a LOT bigger than the stock bulkhead bush in diameter so won't fit!!! I was a bit confused by this as it says it fits petrol models only, so I contacted the great guys at RT Mechanics seeing as they had worked with Powerflex to produce this. Found out that Volvo replaced the bulkhead mount as the original one failed, luckily RT had some in stock and only about £20 so ordered one up. So it is more likely if you upgrade you will need to do the same. Once I got the new bulkhead mount found it a LOT better produced and so put it in a press to remove the original rubber bush, as always a complete pain, and I have to say even harder to remove than the OEM top engine mount bush. Once removed I cut out the rubber still left inside the bulkhead mount and inserted the new bush, no modification needed to the bush unlike I had to do on the Powerflex top engine mount when fitting that. (Picture of the 2 attached, the new bulkhead mount has the OEM bush removed) To remove the bulkhead mount from the car you need to remove the plastic shield below the window, not completely but just enough to get your ratchet and hand inside, that hides all the electric's for the wipers. I then loosened the nuts so the mount started to move downwards, I then removed nut and bolt from the upper engine mount and vertically pulled up the bracket over the top of the engine mount. I then remove the nuts that hold the bulkhead mount and it all came out. I noticed when loosening the bolt that hold the bulkhead mount in place onto the bracket that the OEM bush was rather worn. I then swopped them and put everything back together on the car. (Photo's attached) I started the engine and straight away sounded louder from the outside of the car, weird. I took the car for a spin and as soon as I got into the car there was more noise, I put it into Drive (Auto box) and the whole dash started to vibrate quite a bit (was always quiet before), but once moving it all seems pretty normal. I have to say it really feels like it has transformed the car, I even thought it felt like the car had more responsiveness and everything felt tighter. For me it is a great performance upgrade, but for many Volvo owners the extra noise may not be so welcome.[/quote] Thats funny ive been doing the exzact same job today, quite annoyed and dissapointed, really want more sound, got jetex twin exhaust, kn panel, top purple bush an i still need to cut out atleast one of the many silencers and get this other bulkhead mount, swear my old 2.0L standard with ecotec valve made more sound, im glad to hear its worth the piss about.
Post 213099 by RT MECHANICS on 2009-02-11 21:10:14
[quote=Niles;213096]for the £20 do you get the Bush & the metal round bracket bit or just the bush?[/quote] Hi Niles The Poly bush is £17.00 and the metal new type mount is £18-20 from memory you will need a new metal mount for this bush to fit we have 20 of them in stock as of today :) Also just to add this mount will increase the vibration on idle but does depend how badly worn your old mount is ... Russ
