Post 22011 by swordy21 on 2005-05-20 15:49:08
Just having a think. I was wondering about obtaining another ECU (don't ask me why, not decided), then got wondering if it would be possible to install them so you could switch between them, allowing you to run 2 different maps, ie a frugal one for everyday commuting/start stop traffic, and a full blown one for weekends and trackdays.
Questions
1) Is it possible?
2) How could lit be done?
3) Has anyone done it?
I am guessing that the type of map you can run would be somewhat limited by your particular car, AT vs MT, turbo etc.
Post 22012 by volvotuning on 2005-05-20 15:51:27
[QUOTE=swordy21]
Questions
1) Is it possible?
No.
See above.
See above
[/QUOTE]
What you CAN do is run different maps on the same ECU.
Adam.
Post 22014 by swordy21 on 2005-05-20 15:55:06
Guess that answers that then!
Adam - how can you switch between the maps?
Post 22015 by After_Shock on 2005-05-20 15:56:07
I never saw adams previous car but if im not mistaken it had a few maps on the same ecu?
Believe it was just a switch to change the modes on the ecu?
Post 22016 by Wobbly Dave on 2005-05-20 15:57:01
For those that didn't know Adam had on his 854R (19T and all the whistles and bells) a switchable map in the car. On the dash was a dial which allowed you to switch maps whilst driving. Very trick indeed.
Post 22019 by BrightonBreezy on 2005-05-20 16:52:58
On my old race bike (an Aprilia RSV) the ecu had TWO maps inside and could be switched between them by a little switch under the seat. I had two maps loaded: one optimized for use with an loud, open, race pipe and the other optimized for the standard, more restrictive, quiet pipe. Then I could just switch the ecu to match the end can required by the circuit I was visiting at the time.
This was a standard feature of the ecu and came from the factory with two identical maps loaded.
Post 22023 by Goof on 2005-05-20 17:48:03
Is it really worth doing? - thought that the RICA map gave better economy than std map anyway???
Post 22028 by Ross9 on 2005-05-20 18:27:23
Yeah but you could have two RICA maps, one that only gave 280 bhp say when foot to floor, enough for day to day etc and overtaking, then one that gave full boonah wheelspinning, terrible mpg mode for the weekends lol.
Ross
Post 22033 by After_Shock on 2005-05-20 18:59:53
As Ross says or you could have 310 and then 340 or something daft! Turns an everyday car into both an everyday one and a weekend car in one.
Post 22039 by pzorb on 2005-05-20 19:29:15
What's the problem with swapping in ECUs then? I was thinking of getting a standard ECU as a spare (and for when the car isn't being driven by me, I don't need my friends learning with 280bhp...) - I'd be curious as to why it wouldn't work...
Martin
Post 22043 by After_Shock on 2005-05-20 19:34:17
Well it would work but theirs no point, you would need to buy an extra ecu, need to pay to get it re-mapped and then everytime wanted to change the modes have to get out and change them.
Makes alot more sense in everyway to just have them built into a switchable single ecu.
Post 22057 by dave on 2005-05-20 20:37:59
there is a tuning company that have a switchable ecu for vw's, cant remember the name of the tuners, you would get 3/4 programs, standard, 95 ron. 98 ron, etc
it would work off the cruise control stalk, if car had cruise, fitted another cruise stalk, didn't cost too much more for it
dave
