Post 224815 by LeeT5 on 2009-04-21 17:11:48
All AWD owners are or should be aware of the costs involved regards the infamous Propshaft. £750 will get you a new one or £250 will buy you a repair kit (for one bearing only). Having every invoice on my car i knew that the prop had been repaired once to the tune of £380. At the time of repairing my own car i had researched this matter until i was fed up with it and decided to tackle it myself. Mainly because the tinkling noise and vibration was starting to piss me off to say the least.
you will need a jack, two ramps, flat surface to work on, Tub of good quality grease (i used Silkolene Pro RG2 high melting point grease) £15. A few tools that will be obvious once you have a look under your car and read this 'How to'.
Here we go then....:ready2go:
Firstly, raise your car off the deck...all of it, or you will struggle! Point to note: ALL 4 WHEELS MUST BE FREE TO ROTATE.
Be especially careful where you jack from and where you put your axle stands.
Next (using a buddy) get your buddy to rotate a wheel, ensuring hand brake is off and car is in neutral, as you lay underneath, working from front to rear and undo the CV bolts for the propshaft. Front CV, Rear CV and then center support bearing, in that order. It is vital that you do not undo the center support bearing until last as this will make removal of the CV bolts almost impossible. The prop is not heavy, i just layed it on my chest when i removed the center support bearing and then slid out from under the car with it ontop of me. Prop removed you will see this...
Front CV Transfer box output face
Rear CV with Torque tube (highlighted yellow)
Next you need to check the condition of the support bearing seen below...
Your bearing should rotate smoothly with a knats cock amount of free play. Anything more and your bearing will need overhaul, which means sending the entire prop to a bearing company.
I researched these bearings and found only two company's that recognise and could replace the shaft with the correct bearing. All bearings have numbers stamped on them and it is this that the company needs to cross reference with it's own make of bearing. Off the top of my head your looking in the region of £50-80 and that is for the bearing only!
Anyway, if your bearing is ok then continue on. Using a blunt spoon (only joking!:biggrin:) a large flat head screwdriver, gently tap off the end cap then pull back the gaiter to completely expose the CV bearing.
Then using carburettor cleaner, give the bearing a good degunge. Mine was bone dry so i just spayed some WD40 and then proceeded to strip down the bearing, cleaned it all up until it looked like this...
Ignore the circlip (highlighted yellow) as you don't need to remove it. Becareful not to damage the cork gasget (3 red arrows)
Proceed to do exactly the same with the rear CV as i garantee this will be in the same sorry state as the front and you may aswell kill two birds with one stone.
Tea Break :biggrin:......................
............................................Tea break over :cry:
Assembly
Assemble the bearing dry ensuring you take your time and do not force any of the balls into the cage. Be patient :B_thumb:
Using copious amounts of this stuff vvvvv (use a good quality high melting point bearing grease)...
...pack as much grease into the end cap and gaiter as you can....Then tilting the bearing at an angle work as much grease as possible in the bearing race ensuring all metal surfaces are coated.
Then using two bolts fit the end cap and align the holes...When you fit the end cap and push it home you want grease to be spilling out of every orifice. If it doesn't, take the cap off and pack more grease into the bearing. You will never fill it 100% so don't worry.
It is vital that the bolt holes line up with the end cap or you won't be able to line up the holes on the face of the transfer box output and Torque tube input face.
Refitting to the car is the opposite of removal. Take your time, you do not want to strip a bolt at this stage!! Re torque the bolts to whatever they should be (i used FT, thread lock and my good judgement)
Clean all your tools away, drop yer car on the floor and take her for a road test.
No more tinkling, vibrating or any prop noises whatsoever.:beer: You should have time at the end of the day to go for a nice drive to a good pub and treat yourself to a beer and think of all that wonga you've just saved.
Post 224818 by Al115 on 2009-04-21 17:35:25
Talk about useful - thanks for taking the time to post this up. Good man!
Post 224830 by LeeT5 on 2009-04-21 18:20:36
[quote=Al115;224818]Talk about useful - thanks for taking the time to post this up. Good man![/quote]
No worries! I almost gave up cos i use firefox and nearly at the end i accidently closed the tab for this page :splat:....had to start all over again. Taken me 4 hours! I hope it was worth it.
Post 224841 by Dangerous Dave on 2009-04-21 19:46:15
Nice one matey. Fantastic write up.
I did this to mine ages ago (but forgot to take pics for a how-to LOL), but now the front UJ gaitor has broken, so I'm gonna try and fit a CV boot to it somehow.
P.S. I find it easier to write a how-to in Word, then copy and paste it into here when ready.
Post 224899 by LeeT5 on 2009-04-21 23:44:32
Fitting the gaiter will be easy. You will just need to remove the circlip (circled in yellow) then remove the bearing race. Cut away your old gaiter and slide on the new one. Let us know in this thread if you can get the gaiter on its own from dealer.
Post 224900 by Tomcat on 2009-04-21 23:45:37
Nice thread Lee, thanks for taking the trouble.
Post 224902 by LeeT5 on 2009-04-21 23:49:00
[quote=Tomcat;224900]Nice thread Lee, thanks for taking the trouble.[/quote]
I did this last summer. Can't believe it's taken me so long. No problem!
Post 224927 by Justin on 2009-04-22 08:26:21
The Carlsberg of how-too's :) thanks Lee.
Post 224932 by Dangerous Dave on 2009-04-22 09:14:20
The gaitor is not available on its own (according to Rufe) You can only buy the propshaft as a whole.
Post 225028 by LeeT5 on 2009-04-22 20:38:04
[quote=bomb192uk;224932]The gaitor is not available on its own (according to Rufe) You can only buy the propshaft as a whole.[/quote]
That sucks...expensive gaitor then!
Post 225062 by KARL on 2009-04-22 22:29:46
Thanks Lee
You are a star for that write up.
Many Thanks mate.
Karl
Post 225422 by muscas on 2009-04-24 23:50:41
Terrific write up Lee, thanks for going to the trouble.
All the best
Patrick
Post 230467 by LeeT5 on 2009-05-19 19:08:20
Cheers for all your comments guys and gals! :B_thumb:
Post 230547 by fireclown on 2009-05-19 23:45:25
it is nice. when folks take the time to do stuff like this. thanks.
Post 230551 by Dangerous Dave on 2009-05-19 23:53:54
Think I've found a company that will do replacement propshaft joints and boots for the awd.
Need to confirm sizes though.
http://www.merlinmotorsport.co.uk/GKN-CV-JOINTS-CV-Joints/c295_296/index.html
Post 311019 by v70rade on 2010-05-25 20:06:06
Hi All,
Firstly, my thanks to Lee for the brilliant original write up - I wouldn't have even attempted this job if it weren't for your article.
I thought it might be of some use if I updated this post with my latest findings as of today; my propshaft is currently dismantled on a bench at work awaiting spares.
In addition to the above comments, I can now add the following info (Based on my 1999 / 2000 MY V70R): -
1. There is no need to lift the entire car off the ground; I did it by lifting the right hand side only and supporting on axle stands. (An assistant is a good idea as you'll need to lock and release the prop for each of the six FWD bolts).
2. The FWD Coupling that Volvo say you can buy from them (for lots of £££) is the same as the Rear. - So by definition both can be replaced.
3. Both the FWD and Rear couplings can be removed (By removing the Cir-Clip Lee Circled in Yellow) and the use of a puller (one of mine needed pulling; the other was removed by hand).
4. The FWD & Rear Shroud and Rubber Gaiters can be replaced separately (No need to buy the complete Volvo front Kit).
5. Provided all of the components used are fitted correctly and, I would recommend with new bolts from Volvo (Make sure they are all the same length per coupling) - No balancing would be required.
6. The bad news, I still cannot find anyway of replacing the centre bearing or UJ without sending the prop away. But mine are both fine after 124k miles.
PARTS: -
http://www.baileymorris.co.uk/pdf/bm_catalogue.pdf
http://www.baileymorris.co.uk/contact_us.asp
The parts are currently listed on p.207 of the catalogue. But the key items are listed below. The top three items are the bearing assemblies and the bottom three are the rubber shroud / gaiters. All parts listed can be identified by the LOBRO number on the bearing outer casing (Can be seen with the prop on the car)
VOLVO
BMCV15 VOLVO CV JOINT (78MM O/A - 65MM PCD) USE WITH DL1418-78B LOBRO REF
BMCV11 VOLVO CV JOINT (86MM O/A - 74MM PCD) USE WITH DL1418-86B
LOBRO REF # 7153050177001
BMCV14 VOLVO CV JOINT (94MM O/A - 80MM PCD) USE WITH DL1418-94B
LOBRO REF # 7153100177006
DL1418-78B VOLVO CV SHROUD & RUBBER (USE WITH BMCV15)
DL1418-86B VOLVO CV SHROUD & RUBBER (USE WITH BMCV11)
DL1418-94B VOLVO CV SHROUD & RUBBER (USE WITH BMCV14)
For an Idea of prices, mine has the 7153050177001's fitted, the bearings are about 85 quid + Vat each, and the Shrouds are about 15 quid + Vat each.
The bolts are about 60 pence each + Vat from Volvo (The dealer will need the length of the bolts to order, so you'll need to measure first).
Delivery from Bailey Morris was about 10 quid and that's for TNT Next day.
Total cost for my prop £60 (not reassembled and fitted yet! – but fingers crossed).
Hope this updated info helps someone else.
Ade.
Post 323951 by dgs666 on 2010-08-02 17:15:20
just found some prop problems on my v70r. this thread helps explain an awful lot, however...mechanic has just reported that i have front bearing gone,centre prop mount gone and possibly uj,s. Now if that is all that is wrong then i would be quite happy to remove the propshaft and get these things fixed by a specialist prop shop( i have already found one in Luton), firstly do the things above mean that i will have any trouble removing the prop, the broken mount being my main concern,and also roughly how much do you think those 3 items will be to repair,250-300 quid i can live with but any more than that and i may attempt doing it myself. cheers for any help. Shame , was gonna get it remapped this week , that,ll have to wait now.
Post 335199 by darowi on 2010-10-01 17:12:22
Good thread!:worship:
I tried to pull my propshaft yesterday in order to overhaul my bevel gear. Sadly before i have found this nice thread!
The outer bearing case is corroded to the angel gear flange, and without knowing where to disconnect the cv I accidently pulled the inner cage out of the assambly having the balls falling out, the gaiter was destroyed also.
Has anyone bought this gaiter from the linked webshop?
My center bearing has slight play and feels ver dry. I have got a prize of about 300 gbp for the repair here in Germany,
is that a good prize?
Post 335236 by Dangerous Dave on 2010-10-01 19:28:06
One of the members on here had their centre bearing refurbed for around £150 I think
