Post 2009 by Bracer on 2004-11-17 16:24:15
1-1-1 no fault 1-1-2 solenoid s1 circuit short to 12 volts 1-1-3 ECU fault 1-1-4 break in drive mode selector circuit 1-2-1 Solenoid s1 circuit short to earth 1-2-2 break in solenoid s1 circuit 1-2-3 solenoid STH circuit short to earth 1-2-4 driving mode selector circuit short to earth 1-3-1 solenoid STH circuit break or short circuit to earth 1-3-2 fault in ECU 1-3-4 incorrect ignition module load signal 1-4-1 oil temp sensor circuit short to earth 1-4-2 break in oil temp sensor circuit 1-4-3 kickdown switch circuit short to earth 2-1-1 fault in ECU 2-1-2 solenoid S2 circuit short to 12 volts 2-1-3 throttle position signal too high 2-2-1 solenoid S2 circuit short to earth 2-2-2 break in solenoid s2 circuit 2-2-3 throttle position signal too low 2-3-1 irregular throttle position signal 2-3-2 no vehicle speed sensor signal 2-3-3 incorrect speedometer signal 2-3-5 oil temp too high 2-4-5 torque limiting circuit brake or short circuit to earth 3-1-1 No transmission RPM sensor signal 3-1-2 transmission RPM sensor signal faulty 3-1-3 gear position sensor (PNP) -incorrect signal 3-2-2 incorrect gear ratio for given roadspeed 3-2-3 lock up slippage or not engaging 3-3-1 solenoid SL circuit short to 12 volts 3-3-2 solenoid S2 circuit -brake in circuit 3-3-3 solenoid S2 circuit short to earth
