Post 2010 by Bracer on 2004-11-17 16:28:01
111 No DTC set 121 Left front wheel sensor, faulty signal <40 km/h 122 Right front wheel sensor, faulty signal <40 km/h 123 Left rear wheel sensor, faulty signal <40 km/h 124 Right rear wheel sensor, faulty signal <40 km/h 125 Signal faulty from at least one wheel sensor for a long period 135 Control Module faulty 141 Faulty pedal sensor, shorted to ground or supplly 142 Faulty brake pedal switch, open or short 143 Control module faulty 144 Brake discs overheated 151 Left front wheel sensor, open/short to battery 152 Right front wheel sensor, open/short to battery 155 Rear axle sensor open/short to battery 211 Left front wheel sensor, not signal on moving off 212 Right front wheel sensor, no signal on moving off 213 Left rear wheel sensor, no signal on moving off 214 Right rear wheel sensor, no signal on moving off 215 Valve relay, open/short 221 Left front wheel sensor, ABS operation signal missing 222 Right front wheel sensor, ABS operation signal missing 223 Left rear wheel sensor, ABS operation signal missing 224 Right rear wheel sensor, ABS operation signal missing 231 Left front wheel sensor, signal missing 232 Right front wheel sensor, signal missing 235 Rear axle sensor, signal missing 311 Left front wheel sensor, open/short 312 Right front wheel sensor. open/short 313 Left rear wheel sensor, open/short 314 Right rear wheel sensor, open/short 321 Left front wheel sensor, irregular >40 km/h 322 Right front wheel sensor, irregular >40 km/h 323 Left rear wheel sensor, irregular >40 km/h 324 Right rear wheel sensor, irregular >40 km/h 411 Left front wheel inlet valve, open/short 412 Left front wheel return valve, open/short 413 Right front wheel inlet valve, open/short 414 Right front wheel return valve, open/short 415 Rear valve open/short 421 Rear wheel inlet valve circuit, open/short 422 Rear wheel return valve circuit, open/short 423 Traction control system valve, open/short 424 Pressure switch for TRACS, faulty or short circuit 441 Control module faulty 442 Pump pressure low 443 Pump motor, electrical or mechanical fault 444 No power supply to valves in hydraulic unit
