Post 240721 by Knight Rider on 2009-07-09 21:09:29
Hey guys.
General musing really........last couple of weeks my C70 seems a little down on-power. Drops down ok' ( auto box ), and still pulls, but doesn't seem to pick up quite so quickly, or at least it doesn't feel like it..
...i haven't done any diagnostic checks ( as i don't know how ) but any ideas at all, or things i should check??
Post 240749 by AlanG on 2009-07-09 21:52:49
You in a T5 or an LPT matey? Vac leaks are the usual headache.....
Post 240762 by AlanG on 2009-07-09 22:10:02
Ok bud. Vac leaks are the bugbear of these cars,but very easily cured. Can be awkward and knuckle scraping but in general very simple. They run on a very simple system and it only takes one to f**k the whole running of the car up. Tell-tale signs are generally unpredictable idle speed and "hanging revs"........Do you have any of these?
Post 240765 by Knight Rider on 2009-07-09 22:12:07
revs seem to idle ok, but it does seem to hang onto the revs longer than usual...
Post 240771 by MIKESC70T5 on 2009-07-09 22:15:16
The cure is get a manual gearbox lol.
Post 240772 by Knight Rider on 2009-07-09 22:16:50
[quote=MIKESC70T5;240771]The cure is get a manual gearbox lol.[/quote]
lmao......cheers, but i think i prefer the lazy option of a auto
Post 240773 by t5 pete on 2009-07-09 22:17:04
Does the car still boost fully
Post 240775 by AlanG on 2009-07-09 22:17:23
[quote=Knight Rider;240765]revs seem to idle ok, but it does seem to hang onto the revs longer than usual...[/quote]
I know this probably will sound an odd q,but is this with ECC on or off?
Post 240782 by Knight Rider on 2009-07-09 22:25:55
Both ( i think ). yeah still boost's but to be honest the way i drive the revs never go much over 4000 anyways before it changes up a gear
Post 240789 by AlanG on 2009-07-09 22:37:00
Right,generally speaking,when the ECC/Air Con is operative the engine management system behaves in a completely different manor........stepper motors etc. I would still be tracing the vac system for leaks as they are famous on here for this. Is your car pre ME7? If so I'd be looking to the timing side of the inlet manifold. There is a vac elbow hidden in there that WILL fail at some point. This results in unpredictable idle speed and hanging revs.
Post 240796 by Knight Rider on 2009-07-09 22:46:14
no is a 2001 ME7 model, just seems like i have to push the engine harder to get upto speed, than i did before, when it used to be effortless....
Post 240805 by AlanG on 2009-07-09 22:58:36
One well known major fault with the ME7 is the ETM (electronic throttle module) Sorry if I'm patronising with the breakdown!! These seem to cause all manors of problems and in some cases Volvo will upgrade as a recall. Basically they are sh**e. They restrict your ability to tune your car but you do say yours is the 2.3 so you have options as it's the strongest lump of them all. You don't say if it's lit it's lambda on the dash which is your starting point for fault code reading,but a general health check wouldn't go wrong. Vac pipes mate.........a certainty.
Post 240807 by Knight Rider on 2009-07-09 23:03:34
No not patronising, as i don't really know what it is im supposed to be looking for!
No nothing has come up nor lit the dash up, just 'feels' like its lacking some previous get up n go !!
Post 240826 by AlanG on 2009-07-09 23:27:56
[quote=Knight Rider;240807]No not patronising, as i don't really know what it is im supposed to be looking for!
No nothing has come up nor lit the dash up, just 'feels' like its lacking some previous get up n go !![/quote]
Start at the beginning my friend,vac pipes. As far as I read the ME7 is not too far removed from the original T5 where this is concerned. There are a few omissions namely the little b******d at the inlet. A stage 0 tune is always a good place to begin...........Plugs,dis cap etc,but you describe a sudden loss which would suggest a failure of a component. Rule out the vacs and get back to us. I'm sure we'll find the fault.
