Post 241148 by rcc1977 on 2009-07-11 13:33:26
Has anybody changed their radiator on a C70? Got the radiator but dont know if its an easy change, or if its going to be one of those jobs that you wish you'd never started!
Changing the rad isn't usually that bad a job, provided you've wielded a spanner in anger before.
if its anything like the 850 t5 i changed mine in a few hours
If it is a T5 it will be part of the 3 part radiator pack. (Intercooler, Radiator and A/C condenser) Is this a serious leak? because you can use radiator repaing solutions if it is a dribble. If you do have to change it get the haynes destruction manual. Essentially you start with the stuff (relays and the like) just behind and under the plastic panel above the rad pack. Assuming you have emptied it, remove the hoses - there are 2 bolts either side of the rad pack IIRC that hold it to the car.. That is most of it. The specifics should be easily followed in Haynes.
It's leaking enough to empty the expansion bottle over a couple of days. I've changed a couple of rads before but they seemed more accessable than this one. Its not Turbo'd so thats one less thing to worry about! Did you guys remove the plastic slam panel first or can it be done in place?
No just the bits hanging down off that panel where you will normally find some relays.
