I-pod
Post 23688 by alan on 2005-05-30 19:25:37
this may have been asked before buyt here goes. can you fit an ipod to an ordinary volvo head unit (sc803 if thats right) have just got one and would really like to fit it in car without changing my head unit as i like the standard look, any help or advice would be greatfull regards Alan
Post 23689 by Vikingxl on 2005-05-30 19:34:20
Try these sites they may be of some help http://www.ghc.co.uk/icelink/ http://www.ipodmycar.com http://www.dension.com Or try ringing procell media on 01948 665048 or Progressive Consumer Electronics Ltd Tel: +44 (0) 20 8572 9573 Fax: +44 (0) 20 8577 3320 Rich
Post 23691 by Vikingxl on 2005-05-30 19:37:15
The other option is to fit an mp3 head unit straight into the car.They are a bit hard to find though and you may end up having to import something yourself.See the pics in my vb garage for my head unit. rich
Post 23729 by alan on 2005-05-30 20:58:08
only problem is that no one quotes for volvo, does anyone know if any other manufacture is the same. thanks for help richsisson Alan
Post 23777 by M44K TS on 2005-05-30 23:49:46
you could try using an fm modulator and get an adaptor to go from 3.5mm jack to phono. That should work if you can't retro fit one to the standard volvo unit
Post 23799 by Vikingxl on 2005-05-31 05:10:53
I tried an fm modulator and the sound wasnt too bad but you get no battery charging or head unit control.I went through all this last year and in the end just bought the head unit.If you want to try a modulator try the following link. http://www.everythingipod.co.uk Or maybe this one. http://www.advancedmp3players.co.uk/shop/product_info.php?manufacturers_id=46&products_id=251 Rich Also dont know if this is any good but you might be able to use this with your head unit if it is a cd changer probably worth emailing them an enquiry anyway http://densionusa.com/dmp3_info.htm Good luck
Post 23802 by NugentS on 2005-05-31 06:30:38
I think that pwcars (www.pwcars.co.uk) have an answer. Ring and ask for Dave in Sales. Sean
Post 23811 by Kent Canary on 2005-05-31 09:59:03
The short answer was (certainly a few months back) no. The suggestion was that the Volvo head units used an Alpine protocol and though they have released a specific converter I dont think anyone here has tried it. I use the Denison Icelink which is a powered cradle and is controlled from my head unit, but i have a Sony single DIN head unit as I took the Volvo one out anyway. It all works fine here but as I say unless something new has come along there is not a solution for the SC range of stereos.
Post 23814 by alan on 2005-05-31 10:47:05
Thanks for your help. i bought an i-trip that will do the job for a while. Alan
Post 23855 by BagR on 2005-05-31 12:33:38
I bought a maplin hard wired FM Modulator. It all hides in behind the dash, and plugs into your ariel jack, with your normal ariel piggy backing unto the top of it. You then are supplied with a switch that changes between your Mp3 player or Radio Reception. It means the quality is spot on, as your not suffering from bleed over, and you have a 'hard wired' connection between the Mp3 and CD player. The only thing i had visable was a wee 3.5inch jack, which pluged into my Mp5 player which sat in a cradle. Gonna fit it to the Volvo in the next week or two, so i'll let you know how i get on! Andy
Post 23862 by pzorb on 2005-05-31 13:35:45
My housemate has the Belkin TuneCast 2. It has both auto-off and car charging modes. It's crappy compared to a tape-through device*. Like radio in a tunnel. Could be because the back of the car (where the aerial on my 855 is) is so far from the mp3 player upfront! Eitherway I personally wouldn't take a headunit unless it a) had a tape deck (for above reasons) or b) had phono'/jack input. I haven't found the latter for sale as yet, but apparently the newest batch of cars for younguns have 3.5mm jacks located in the glovebox for iPods, Zens etc. Not too sure how useful it'd be in the glovebox but you could run a cable! Martin (*I got it for C$10 in Walmart, it's excellent! Obvious losses due to tape so about 22KHz fidelity, but doesnt require any turning up of the stereo to use it like every other one i've used/heard. As clear as it could possibly be for tape! Bargain!)
Post 23943 by M44K TS on 2005-05-31 19:51:27
[QUOTE=BagR]I bought a maplin hard wired FM Modulator. It all hides in behind the dash, and plugs into your ariel jack, with your normal ariel piggy backing unto the top of it. You then are supplied with a switch that changes between your Mp3 player or Radio Reception. It means the quality is spot on, as your not suffering from bleed over, and you have a 'hard wired' connection between the Mp3 and CD player. The only thing i had visable was a wee 3.5inch jack, which pluged into my Mp5 player which sat in a cradle. Gonna fit it to the Volvo in the next week or two, so i'll let you know how i get on! Andy[/QUOTE] that's what i had in my peugeot when i had my tv and dvd installed, was a doddle to do aswell
Post 23970 by BagR on 2005-05-31 22:35:20
[QUOTE=T5Mark]that's what i had in my peugeot when i had my tv and dvd installed, was a doddle to do aswell[/QUOTE] i had it in a 306. think it was easy cos the dash is made of cardboard and easy to get in behind lol. the 850 could be a different proposition...
Post 23993 by Kent Canary on 2005-05-31 23:10:49
The FM transmitters are illegal in the UK
Post 24027 by M44K TS on 2005-06-01 00:11:07
are they? oops! Oh and BagR, my old pug still has teh holes in the dash where the switch was fitted for the fm modulator. When i traded it in for the Volvo, they asked what was there, i said it was for NOS.
