spark plug issue
Post 248996 by will_s1cab on 2009-08-12 22:23:06
i just got my v70 t5 and 1 spark plug keeps oiling up and then obviously the engine misfires any help with what this could be? i dont have a manual yet too look up! cheers Will
Post 249001 by t5 stealth on 2009-08-12 22:35:18
is it the plug gap thats oiling up or the ht lead where it goes over the plug. if its on the lead its probly the rocker cover/cam cover leaking oil, if its the plug gap oiling up it could be a number of things, valve guides,piston rings,head gasket,cracked head etc etc. best to take it to your local garage & let them check it out before it becomes a big issue,& a big cost
Post 249003 by Dangerous Dave on 2009-08-12 22:53:19
Could be PCV system dumping shed loads of oil, or the turbo oil seals.
Post 249051 by will_s1cab on 2009-08-13 12:05:24
its the plug gap the ht leads seem fine its just the one plug on the left side of the engine as u look at it
Post 249234 by smudgethecat on 2009-08-14 12:09:07
sounds like significant engine wear has occured oiling up plugs normally indicates serious bore /ring wear
Post 249344 by will_s1cab on 2009-08-14 21:40:32
it seems to be running ok atm like i say its just one ov them
Post 249446 by mexybhouy on 2009-08-15 14:40:33
Sounds like valve stem or bore/ring wear in that cylinder!! maybe do a compression test just to compare???
