Post 249511 by Clan998 on 2009-08-15 22:41:59
Hi all,
The boost gauge has stopped working havnt had a chance to look at it yet . Its not quite as fast as normal too ..Still drives ok.
Any idea's on where to start looking ? Im hoping its a pipe off some where or spilt hose ?
Cheers Rich
Post 249515 by AlanG on 2009-08-15 22:56:27
Hey Rich,check the white pipe running across the top of the radiator,it supplies the guage. It has 2 joins,I believe and chances are one has come adrift. It's a mechanical/vacuum affair so no need to worry about expense. Had the same happen to mine. HTH..
Post 249586 by Clan998 on 2009-08-16 18:50:12
[quote=AlanG;249515]Hey Rich,check the white pipe running across the top of the radiator,it supplies the guage. It has 2 joins,I believe and chances are one has come adrift. It's a mechanical/vacuum affair so no need to worry about expense. Had the same happen to mine. HTH..[/quote]
Cheers Pal
You were spot on a joint had come apart ... Very easy fix total under 1 min :-) wish they were all as easy as that !
Post 249594 by AlanG on 2009-08-16 19:37:03
You're most welcome.....Glad I could help.:D
