Post 253532 by sen on 2009-08-31 20:53:13
Reet guy's does anybody have this kit? If so where do i cut into to locate this baby ive bought it off a fellow member on here at a very reasonable price??? [ATTACH]7172[/ATTACH]
it needs to go as close to the throttle body as possible mate
Thanks mate ive got the blanking plate too from forge, do in need to fit this or can i just block the pipe from the existing up. Thanks again
[quote=sen;253535]Thanks mate ive got the blanking plate too from forge, do in need to fit this or can i just block the pipe from the existing up. Thanks again[/quote] no you need to fit the plate, just blocking the pipe won't give enough pressure on the recirc valve & it will be forced open when it comes on boost no problem mate
[quote=p fandango;253536]no you need to fit the plate, just blocking the pipe won't give enough pressure on the recirc valve & it will be forced open when it comes on boost no problem mate[/quote] You have pm mate
[quote=sen;253538]You have pm mate[/quote] replied
Top man
[quote=sen;253546]Top man[/quote] :hug: lol thanks mate
