Auto transmission fluid change "nightmare"
Post 257900 by willi on 2009-09-16 19:56:45
Having had my autobox flushed and fluid changed it is now worse than before i started. After the change it was fine but within 3-4 days the gear changing became erratic at low speeds and held longer in first to second gear. "Cookie" was right,the fluid that was used for the change by the gearbox company was obviously an inferior quality to that of volvos own. I have now got to buy volvos own and get the company to re-do the job or alternatively get it done at volvo at a much greater cost and be done with it.. I have really bolloxed up..:mad::scared::doh::cussing::cry: If i buy the fluid from volvo how much will i need??? Can i get away with 8 ltrs,or will i need 12 ltrs???
Post 257905 by scooter on 2009-09-16 20:11:10
from previous gear boxs i have found if to much or to little the gear changing will be terrible with gear boxs they need to nearly 100% correct regarding the amount i would go with what it states as the fluid will be in the filter
Post 257912 by cookie on 2009-09-16 20:21:32
Have you checked level - remove the pipe from intake to air box (just unclips) run engine, hold in each position for a few seconds (down to L and back to park), switch of engine and check dipstick I would also ask the garage exactly what make and spec of fluid they used, if they say Comma then Personally I'd bite the bullet and replace with genuine If level is low, top up, if to high, drain a bit out (17mm bolt IIRC in the side at bottom of gearbox), recheck level as B4, and if nessasary remove a bit more. if level is fine, or comma has been used, then get the fluid, the clip for the top cooler hose, and the 2 O' rings, and do it yourself, with someone to help 12 litres of fluid, clip, 2 O'rings was just around 120 quid mark. without knowing whats in there, and if level is fine, level is critical, hence why I measured exactly what came out and replaced with exactly the same amout, each time, by measure on jug, and by always standing jug of old next to jug of new and visually checking as well.
Post 257917 by willi on 2009-09-16 20:37:37
Thanks,i will go through that procedure hopefully at the weekend.
Post 257921 by phil_woods on 2009-09-16 20:54:37
You have all got me worried now I have bought new grarbox oil from my local auto store and I was going to do the change as soon as I could. I don't know if I should bother now lol I can't remember what type the new oil is it's in my garage, I'm in my dressing gown and it's too cold outside to check... I ain't getting footy studs for that lol
Post 257922 by sen on 2009-09-16 20:58:05
[quote=phil_woods;257921]You have all got me worried now I have bought new grarbox oil from my local auto store and I was going to do the change as soon as I could. I don't know if I should bother now lol I can't remember what type the new oil is it's in my garage, I'm in my dressing gown and it's too cold outside to check... I ain't getting footy studs for that lol[/quote] Get in the garage you big woosy its not cold lol
Post 257923 by phil_woods on 2009-09-16 21:01:23
Lol it's cold in my garage!! And I haven't got any undy's on lol
Post 257926 by sen on 2009-09-16 21:03:41
[quote=phil_woods;257923]Lol it's cold in my garage!! And I haven't got any undy's on lol[/quote] Too much detail :shockedbi
Post 257931 by phil_woods on 2009-09-16 21:11:32
Lol yeah sorry about that
