fuel return pipe
Post 261434 by hirstyt4 on 2009-09-30 21:24:58
hi All has a 98 t4 got a fuel return pipe and if not why as waste petrol must need to be returned to the tank and does the inlet go though the fpr first then into the rail thanks a very confused mark
Post 261446 by daveforber on 2009-09-30 21:52:28
I'll have a look at the schematic later, but I believe: * There is no fuel return (sorry, couldn't answer why!) * The FPR is immediately before the fuel rail
Post 261450 by hirstyt4 on 2009-09-30 22:01:12
on all cars I've worked on the fuel goes in the end of the rail and out of the regulatorback to the tank.on my t4 that's the opposite
Post 271815 by Enigma666 on 2009-11-29 18:13:27
Ooooh something outdated I can actually answer... Drum roll............... Nope S40 T4 98 has no fuel return line....I know this because it only came as standard I believe on the 2.0 NA engines. As for the FPR, it is attached to the drivers side of the fuel rail and the feed goes directly to this, when fitting an adjustable FPR to T4's you can either....take the fuel lines from a 2.0NA or drill out the T4 line to open up the return pipe section that is there, then run a line to the pump yourself.
