Post 25361 by lighterfuel on 2005-06-08 20:19:13
Hi all
I am a newbie here but thought i would ask. I have a 850 T5 1996 and the strangest thing is happening. When i first start the car and whack on the air con to its coldest point, it works fine for about 20 mins (somrtimes less) and then the air goes warmer, not hot, but not cold. Then when i accelerate hard, the cold air returns. This process goes on and on until i reach my destination. Then, on other days, and not so hot days, it works fine. The mornings on the way to work its always fine. This tends to happen (the problem) during the day and when its been a rather hot day.
When i bought the car, 1 year ago, the aircon was not working and Volvo repaired it and all was fine until a few weeks ago. Does it need re-gassing? I have it on all the time since i purchased the car (aircon).
your help would be greatly appreciated.
Lighterfuel
Post 25382 by splatt on 2005-06-08 21:56:54
I would look to re gas, it needs doing every year or so depending on how you use it.
What did they do to repair it in the first place?
Post 25435 by Viffer on 2005-06-09 10:04:43
Seconded....sounds like a regas....
Post 25442 by swordy21 on 2005-06-09 10:22:03
Mine does this as well. Regas is on the cards.
Post 25488 by Babybadger on 2005-06-09 13:12:54
Any idea how much to regas an aircon?
Post 25489 by Mrsmopp on 2005-06-09 13:14:10
Anywhere between £40 - £80 depending on who you use.
x
Post 25496 by madness on 2005-06-09 13:23:05
park the car tight against a wall , front end on. if the temp goes right up, probably the pressostat that lets gas past to the evaporator inside the car , and a common fault on all 850/v70 . can be tested before fitting to be 100%
i hasten to add
Post 25501 by siamblue on 2005-06-09 13:32:16
Take it to a independant get the aircon codes read if there are any and ask them to do a vaccuum test on it to see how much gas is in there and if it is holding the gas,
This was what was done to mine today at Braydons in North London.
Post 25720 by lighterfuel on 2005-06-10 13:31:06
Many thanks boys, i appreciate the reply's. I will look in to what you suggest with the regassing. Im stunned however, that it needs regassing so soon in just a year, having said that, im not sure what Volvo did to the air con unit when i bought it to get it working, this may not have involved a regas then, so in theory, i dont know when it was last done!
love the site and i do have to say, i just love kicking down and watching MOST cars become a dot in the rear view mirror. It was TOP GEAR that brought my attention to T5's and i will never look back, awesome machine.
lighterfuel
(john)
