Post 277798 by drax on 2009-12-28 10:22:51
All,
I need to replace headlight blubs, but have to remove the front bumper first, so I can un-mount the light unit.
I know that there are a series of nuts to remove, but how in the hell do I get the plastic strips out on either side on the bumper.
Ta
Post 277799 by cornclose on 2009-12-28 10:26:37
Is there a V70 that has to have the bumper removed to change bulbs? It can be done on mine very easily within 5 mins!
Post 277800 by drax on 2009-12-28 10:30:48
The blubs in question are for the Day light running lights which are stuck behind the chassis, so can't get to them without removing the unit.
I'm not going to go to a dealership to have them replace when I should be able to do them myself.
Post 277862 by v70torslanda on 2009-12-28 17:17:01
Assuming a facelifted 05 on model. Are we talking about the orange marker lamps on the side of the headlamp assembly where it meets the wing? Outboard/behind the indicator? Aren't they LEDs?
If it is any other bulb then it will be fiddly but not so bad you need to remove the headlamp . . .
Post 278000 by drax on 2009-12-29 14:07:45
[quote=v70torslanda;277862]Assuming a facelifted 05 on model. Are we talking about the orange marker lamps on the side of the headlamp assembly where it meets the wing? Outboard/behind the indicator? Aren't they LEDs?
If it is any other bulb then it will be fiddly but not so bad you need to remove the headlamp . . .[/quote]
Yep it's the orange marker lamps - can't see any way to get to them without taking the unit out.
Post 278009 by v70torslanda on 2009-12-29 14:58:18
Check with your main dealer.
I'm pretty certain that they are LEDs, in which case, if they've failed, you'll need new headlamps!!!!!
BIGGGGGGGGGGG BUCKS! Euro Car Parts £175 ex vat. (Don't even ask about HIDs)
Just a thought, being ex-plod, it doesn't need the day runners switching on again, does it? Do the triple LED side markers work in the rear lamps?
J
Post 278058 by richiemat on 2009-12-29 20:58:53
[quote=drax;277798]All,
Ta[/quote]
Doesnt show the bolts you refer to but is useful for the rest of the process.
http://forums.t5d5.org/topic/8599-front-bumper-removal/
Rich
Post 278725 by drax on 2010-01-03 15:54:17
[quote=v70torslanda;278009]Check with your main dealer.
J[/quote]
All the side markers are working expect for this one - So I guess it's blown.
