tailgate will not unlock
Post 282652 by scooter on 2010-01-18 15:47:28
yesterday was fine but today i went to something in the boot but the tailgate will not unlock to open all other locks are fine any suggestions
Post 282661 by scooter on 2010-01-18 16:16:47
I am thinking relay due to i have checked all the fuses all fine but the side lights reverse lights and rear fog lights aren't working along with the tail gate Would i be right
Post 282667 by scooter on 2010-01-18 16:32:23
[quote=scooter;282661]I am thinking relay due to i have checked all the fuses all fine but the side lights reverse lights and rear fog lights aren't working along with the tail gate Would i be right[/quote] I have also just found fuel cap not locking as well
Post 282669 by v70torslanda on 2010-01-18 16:54:09
Sounds like the CEM is not talking to the REM
Post 282672 by scooter on 2010-01-18 17:06:14
would you know how to get that fixed
Post 282770 by v70torslanda on 2010-01-18 22:19:49
As the car is multiplex wired, unfortunately no. I think this is a job for your nearest independant or main dealer. Failing that a qualified auto electrician as this is not one you're going to fix with a circuit tester :( Just a thought, you could try disconnecting the battery and reconnecting after a short time, the electrical system may have its knickers in a twist and this might just sort it out. I'm sorry, I don't know anyone in N.I. to recommend. Euro car Parts in Belfast, 02890 689 700 may be able to recommend someone. HTH John
Post 282779 by scooter on 2010-01-18 22:33:21
cheers john i have the obd and software i will connect it tomorrow to see if i have any luck there is a specialist near 5 miles away the car is driving no problems but the stuff mentioned above thanks for the advice
Post 282824 by thebadger on 2010-01-18 23:57:14
Have you tried the reset of the UEM yet? In the car, key in the ignition, position II (not running), pull UP on both front window switches for at least 8 seconds, release them, key out of ignition, now using the remote fob whilst STAYING IN THE CAR, Lock, unlock, lock & unlock (yes you do it twice). This resets the UEM (upper or front electronic moduel). HTH
Post 282897 by scooter on 2010-01-19 13:16:22
badger that didn't work but i was able to get door card of and it is the pipe that slides that is stuck i put some lub on it and it worked for a while so i have thought of buying a new one or refurbed one any body have one available cheap as funds low and willing to post to me in northern irealnd
Post 282898 by scooter on 2010-01-19 13:31:01
The place where i contacted about a new one told me that the new lock might need programmed after installation is it true or is he fibbbing to get me to bring the car back to him
Post 282928 by scooter on 2010-01-19 16:31:46
now the lock is screwing with me it stopped working so i took the door card of again and as soon as it was off it started working again with out doing anything what so ever so put more fluid on it and i will see how things going but i am still after a lock mechanism
Post 282930 by richiemat on 2010-01-19 16:41:53
[quote=scooter;282928]now the lock is screwing with me it stopped working so i took the door card of again and as soon as it was off it started working again with out doing anything what so ever so put more fluid on it and i will see how things going but i am still after a lock mechanism[/quote] i've used these guys a couple of times http://www.salvogroup.co.uk/salvosite.htm and one of those was for a door lock, reasonable price and think there might be a forum discount. They posted the items to me. Does sound like the mechanism is tight though and would need lubrication.
Post 282937 by richiemat on 2010-01-19 17:11:26
[quote=scooter;282898]The place where i contacted about a new one told me that the new lock might need programmed after installation is it true or is he fibbbing to get me to bring the car back to him[/quote] it doesn't need reprogramming
Post 282938 by scooter on 2010-01-19 17:13:30
thats what i thought richie when i looked at the look there does seen to be black box plug that would hold electronics if you know what i mean
Post 283054 by t5 stealth on 2010-01-19 22:21:07
boot latch is £141.00 from dealer. i think ul find its a wiring fault.possibly through the tailgate hinge. check the wiring
Post 283124 by scooter on 2010-01-20 13:18:18
I fingered it out I took the mechanism out and had a look it is the wee white box (9990.6518.0) the rod that rotates was stiff so i took it apart greased it all up and at the moment it is working so if any body nose where where i could get the white box that contains the motor and rod point me in the right direction cheers every body for your help
Post 283153 by mds on 2010-01-20 15:46:53
Hi Scooter guess what yesterday I got home and cant open the tailgate?? All fuses are OK and the Central locking can be heard working, my question is how did you get the trim/door card off the tailgate??? Thanks Dave
Post 283160 by scooter on 2010-01-20 16:11:54
if yours is the same model at the top of the door card right behind the wiper you can bend it out just enough to see down if you look right down you will see a pile of white plastic at the bottom right underneath the white plastic you will see a piece of black plastic square roughly 1cm in the path of the handle pole push it down you should here a click that should unlock the door
Post 283188 by mds on 2010-01-20 19:07:28
Thanks for that, mine is a MY03 V70 T5 SE so I think it should be the same. I will have a go tomorrow and let you know how succesful or not its been. Dave
Post 283303 by scooter on 2010-01-20 22:52:33
mds if you here the central locking it is probably the handle pole has slipped out of the top clip the wee clips car be bought from motor factors about 25p
Post 283314 by thebadger on 2010-01-20 23:38:41
http://cgi.ebay.co.uk/volvo-v70-tailgate-lock_W0QQitemZ110482593489QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item19b94696d1
Post 283379 by mds on 2010-01-21 14:13:03
Hi Thanks everyone, just opened it up took out the lock as I couldnt see anything obvious but the solonoid had become completely dry and very difficult to move, cleaned it and lubricated everything with a light silicon grease. All back together and working like new. Whole thing took less than an hour so I guess I just save a gudzillion pounds at Volvo rates. Just going to do the other P2 V70 now as a precaution, the P1 V70 seems fine (12 years young and never misses a beat, probaly temting fate now) Dave
Post 283382 by scooter on 2010-01-21 14:21:18
[quote=mds;283379]Hi Thanks everyone, just opened it up took out the lock as I couldnt see anything obvious but the solonoid had become completely dry and very difficult to move, cleaned it and lubricated everything with a light silicon grease. All back together and working like new. Whole thing took less than an hour so I guess I just save a gudzillion pounds at Volvo rates. Just going to do the other P2 V70 now as a precaution, the P1 V70 seems fine (12 years young and never misses a beat, probaly temting fate now) Dave[/quote] It feels good when you can get something fixed and you don't have to pay the stealerships
Post 283429 by doylet5 on 2010-01-21 19:17:20
Dont believe it this has just happened to my 2005 V70 t5 needed to get in boot and the tailgate wont open + on key fob i have a boot open button it dont work nightmare any help needed
Post 283442 by scooter on 2010-01-21 19:51:10
follow my instructions it works now mine is working 100% anymore info just post or pm me
Post 284679 by t5 stealth on 2010-01-26 18:30:02
just for info if it helps....... the v70 p2 do suffer with tailgate lock/unlock issues, open the tailgate,on the left hand side behind the panel that opens is a fuse box.....that fuse box does all the electrics on the rear of the car, the relays in there control the central locking, it has a seperate relay for lock & unlock & for each rear door/tailgate/& petrol cap, apparently these models suffer with water getting into the fuse box,be it wet or damp,they corrode the circuit board inside the fuse box, also the conections on the relays may be affected, just pushing or moving the relays can restore the connection to the tailgate. thus sorting the problem, hopefully its just bad connections,rather than a faulty part,it seems that when its faulty it only supplies 8 or 9 volts to the solonoid which isnt enough to trigger it so it wont open, on the plug that goes onto the solonoid is a grey wire & a yellow wire,ontop of each other,these are lock & unlock,check the voltage on each one,ie when lock & unlock,
