Two questions
Post 284352 by ncarnall on 2010-01-25 11:03:18
Hi again, Can anyone help with the following (I did search but couldn't find what I was looking for) Freeing off brake calipers (Front) is it possible to refurbish/ fit new seals etc Noisy power steering pump, I can remember reading a how to about this but darned if i can find it again. How do I change fluid and bleed etc PS car is a 2000 C70 Convertible Thanks in advance Cheers Neil
Post 284357 by v70torslanda on 2010-01-25 11:34:46
Dealer will sell you a caliper slide kit but if the piston is sticking then a refurbed exchange caliper is the way to go. Noisy PAS pump try a fluid change - get the correct stuff from Volvo - if it's still noisy after that then it wants mending with a new 'un. HTH J
