Post 285710 by rick84 on 2010-01-31 12:30:15
Is anyone selling or know where to get hold of bigger injectors for a 940 turbo? They would need to be pretty much plug and play or straightforward swap because I would be fitting them myself. I'm planning on upgrading to a 15g Turbo and running 15psi so I need bigger injectors to accomodate this. Thanks
Post 285828 by smithy on 2010-01-31 20:30:21
[quote=rick84;285710]Is anyone selling or know where to get hold of bigger injectors for a 940 turbo? They would need to be pretty much plug and play or straightforward swap because I would be fitting them myself. I'm planning on upgrading to a 15g Turbo and running 15psi so I need bigger injectors to accomodate this. Thanks[/quote]
if you put a fpr on you will be able to use your standard injectors if you only want to run max 15 psi.
Post 285904 by rick84 on 2010-01-31 23:18:52
[quote=smithy;285828]if you put a fpr on you will be able to use your standard injectors if you only want to run max 15 psi.[/quote]
Oh right, didn't realise that. What FPR is best for this setup? Cheers
Post 286109 by smithy on 2010-02-01 21:04:30
i have a fse fpr that is not a fse boost valve ,the 1 i have is designed for turbo cars so keeps the pressure constant threw the rev range .and you donot need a 960 maf unless you are running 30 percent bigger injectors
