Brake Vibrations?
Post 27297 by gibbo on 2005-06-19 21:12:57
Driving home today all going fine untill, braking gently for the traffic in yet another damn jam i could feel the car slightly vibrating. Killed the stereo, shut the kids up to listen for any noise. As you pull up you can here a slight groaning coupled with the vibration. Apologies for the terminology. I haven't had a chance to investigate further but i am suspecting rear pads as you can't feel anything thru the steering wheel! Has anyone experienced anything similar? If it is the pads what is the recommended replacements? DS2000? Have they been rebadged as DS1265's or something now? If it is the pads i'll replace the whole lot anyway, recommend supplier & cost? Gibbo
Post 27311 by Wobbly Dave on 2005-06-20 00:00:36
VT are the only suppliers in the UK of DS2500 - I can thoroughly recommend them. The DS2000 or DS Performance are also very good fast road pads - ring VT for a quote.
Post 27317 by Bison on 2005-06-20 07:54:20
is the vibration thru car or steering wheel? I had vibration thru steering wheel, turned out to be warped front discs! got brembo's from VT at £36 each but believe you can get them cheaper at German French Swedish or similar. Bison
Post 27319 by gibbo on 2005-06-20 09:04:40
[QUOTE=Bison]is the vibration thru car or steering wheel? I had vibration thru steering wheel, turned out to be warped front discs! got brembo's from VT at £36 each but believe you can get them cheaper at German French Swedish or similar. Bison[/QUOTE] No mate nothing thru the steering wheel, It feels like it's thru the seat very strange? Gibbo
Post 27320 by gibbo on 2005-06-20 09:05:39
[QUOTE=Wobbly Dave]VT are the only suppliers in the UK of DS2500 - I can thoroughly recommend them. The DS2000 or DS Performance are also very good fast road pads - ring VT for a quote.[/QUOTE] Cheers W-Dave i'll be calling them today Gibbo
Post 27322 by siamblue on 2005-06-20 09:39:49
It isn't only VT that sells those pads Motorsportworld sells them at £81 for the fronts, They are not called DS2500 anymore but Ferodo DS Performance pads, Gary
Post 30697 by gibbo on 2005-07-08 11:01:12
Turns out to be the rear pads. Changing them over the weekend. Cheers everyone Gibbo
