Post 290409 by Sihayton on 2010-02-19 12:50:49
The T4 is getting an adjustable Fuel Pressure Regulator fitted at the weekend. Any tips on fitting it and anything I should look out for?
The FPR is this one..........
[quote=Sihayton;290409]The T4 is getting an adjustable Fuel Pressure Regulator fitted at the weekend. Any tips on fitting it and anything I should look out for?
[/quote]
hello mate just a question why are you fitting a fpr to your car is it modded.i fitted 1 to my 940 turbo because i need manual adjustment due to the car not being mapable .if you are fitting it make sure you set the gauge to 3 bar untill you can you can get it on the rollers to set the fuel properly mate
It's got a stainless steel exhaust, k&n filter, dump valve at the moment and is soon to go for a remap hopefully - is it worth sticking it on?
[quote=Sihayton;290414]It's got a stainless steel exhaust, k&n filter, dump valve at the moment and is soon to go for a remap hopefully - is it worth sticking it on?[/quote] personally i would say no because with basic mods and a remap the car will fuel itself just fine mate.that is why they remap cars for more power and better fuel consumpion so the fuel matches the boost etc perfictly mate .
Ah ok I shall shelve that then. Thanks for your help
