Post 291727 by MC_Bob on 2010-02-25 10:51:08
Bought a cheap U480 reader off ebay, seems brill so far!
Its come back with the code P0131, O2 Sensor Circuit Low Volts (Bank1Sensor1).
Any ideas what this could actually mean Lol?
Thanks guys, you been good to me so far :D
Post 291734 by Timo. on 2010-02-25 11:16:29
How much did you pay for your fault code reader?
T.
Post 291737 by Timo. on 2010-02-25 11:22:11
Cool.
I find being able to read car error codes a must. Have had vag com for years and find it really usefull. Now have BMW and Volvo in the household so need a way to read them now.
T.
Post 291772 by Wobbly Dave on 2010-02-25 13:45:51
[quote=MC_Bob;291727]Bought a cheap U480 reader off ebay, seems brill so far!
Thanks guys, you been good to me so far :D[/quote]
O2 sensor is on the blink.
Post 291795 by siamblue on 2010-02-25 15:35:20
A fellow member borrowed my spare o2 sensors i will get them back just incase you want to swap them over,
Gary
Post 291798 by MC_Bob on 2010-02-25 15:41:54
I couldnt appreciate that enough if such was possible!! Im tempted to drive to the car spares shop local and change it in the rain, but would be gutted if its not whats at fault!
Thanks,
Nathan
Post 291857 by streaky744 on 2010-02-25 18:34:13
will check in my autodata book for you on that code, pretty safe bet its the lamba sensor but not sure if its the pre cat or after cat one without looking in the book or on auto data . what year of car is it, model and engine size please?
Post 291858 by t5 stealth on 2010-02-25 18:41:29
p0131heated oxygen sensor (o2s)
bank 1 low voltage,
possible causes......
exhaust leak,wiring short to earth,h02s,ecm
Post 291863 by MC_Bob on 2010-02-25 18:55:09
I assumed it was the front one as its bank 1 sensor 1?
Its a Volvo C70 1998 T5 GT :) Thanks matey.
Whats h02s and ecm?
Thanks aswell mate.
Cheers guys!
Post 291864 by streaky744 on 2010-02-25 18:56:54
my mistake if this code means heated o2 sensor then isn't that the EGR valve ? not lamba sensor.
Post 291870 by t5 stealth on 2010-02-25 19:08:33
most likely is the sensor.
but check the wiring as it lays close to the manifold,if its burnt through somewhere it will short out & cause a fault light,
Post 291895 by MC_Bob on 2010-02-25 20:00:20
Ive assumed it was Exhaust lambda, didnt know the volvo had EGR? Oops! >.<
I had a look underneath in the rain, got it on stands but got a bit fed up lol. Couldnt see deffective wiring, and it doesnt come on as soon as the light is removed, takes a few miles of driving, so im guessing its giving readings out of a bracket or something rather than going straight to ground.
Cheers guys.
Post 292422 by MC_Bob on 2010-02-27 22:32:53
Changed it, so far so good :D
YAY.
