Dodgy tyre wear
Post 27594 by rs_andy on 2005-06-21 21:38:14
Does any elses car wear the left front tyre excessively? Mine seems to have a very slight pull to the left which I'm sure is the cause but when I mentioned it to my dealer they said it was cos she is a big car and I reverse into my driveway and that wears the outside of the tyre? I replaced the nearside front track control arm and it seemed to make it a bit better as the old bushes were shot, any other ideas? anyone know if VT can do an alignment check or something? need to book in with them for 150k service soon anyway...
Post 27596 by John Ret. on 2005-06-21 21:47:06
It'll definatly be wheel alignment/tracking and you can get it done fairly cheap at independant garage. :)
Post 27598 by k690bpp on 2005-06-21 21:50:56
mine wears the inside edge of the left front too, i've had a 4 wheel alignments done but this only made it worse. next thing is to replace the bushes and balljoints.
Post 27607 by gazjacko on 2005-06-21 22:34:10
Outside front left is pure physics. Roundabouts and a couple of ton of fast moving metal wanting to go straight on! Insides wearing, tracking and alignments done first, check the upper mounts which can collapse but when you jack up to check for play, the mount compresses and masks the movement that's there.
Post 27613 by TangoDeltaSierra3 on 2005-06-21 23:16:10
Excuse me for being thick but whats the difference between a TCA, drop link, and balljoints, and does the S70 have an anti roll bar, in fact which bushes are you supposed to change ? Thanks.
