Post 293838 by iron_mighty07 on 2010-03-06 15:16:19
Having given up on my V70 estate I'm concentrating on the S60 daily(2002 2.0T) I've been using for a while and I'm a tad perplexed :confused:with the low tone knocking noise from what feels/sounds like the N/S front corner. Checked the obvious things(immediate thoughts were bushes),but had already changed some parts last year(bottom arms and ball joints), and had a good look and feel underneath(drop links(with vehicle on ground) but nothing that feels to move comparitive to the noise I'm experiencing. O/S drop link has a small amount of play and I'll be changing that. I keep reading about top mounts and spring seats being a route cause of such issues but there's no play in the top mount that's obvious to see/feel - is it still possible these could be the issue(vehicle is at 86k miles). Appreciate this question asked before but curious to confirm whether there's a chance this might be the case even without any visual indicators? Any contributions gratefully received as I need to get if tracked up and want to do this work before I have to rave everything out again!. Many thanks!
