Post 297675 by gotmeaT-5 on 2010-03-23 22:14:22
What work is necessary to fit a big bore throttle housing on my 850 T5, or is it a straight swap, and Is porting the manifold necessary to match the diameter of the housing ? Most importantly where can I get a big bore throttle housing in the UK ? Found one in the USA but import tax will be a killer
gotmeaT-5
Post 297695 by Rnash2002 on 2010-03-23 23:22:16
[quote=gotmeaT-5;297675]What work is necessary to fit a big bore throttle housing on my 850 T5, or is it a straight swap, and Is porting the manifold necessary to match the diameter of the housing ? Most importantly where can I get a big bore throttle housing in the UK ? Found one in the USA but import tax will be a killer
gotmeaT-5[/quote]
Tim Williams on here does a modded one.
Post 297700 by Dangerous Dave on 2010-03-23 23:39:43
Or you could get one off a 960 they are bigger. Pedro has done sumthing like that on BT
see thread here
http://www.vpcuk.org/forums/showpost.php?p=207515&postcount=12
Post 297718 by p fandango on 2010-03-24 05:16:16
[quote=gotmeaT-5;297675]What work is necessary to fit a big bore throttle housing on my 850 T5, or is it a straight swap, and Is porting the manifold necessary to match the diameter of the housing ? Most importantly where can I get a big bore throttle housing in the UK ? Found one in the USA but import tax will be a killer[/quote]
as said i'm using one off a Volvo 960 (3litre V6). The bolt pattern is the same but you do need to bore out the manifold a bit, that only takes 5minutes with a flap sander. The 4 wires for the throttle position switch need extending as the switch is turned 90degrees, & obviously you'll need a bigger diameter pipe to go on the end as its quite a bit bigger
Post 298124 by gotmeaT-5 on 2010-03-25 21:41:06
[quote=p fandango;297718]as said i'm using one off a Volvo 960 (3litre V6). The bolt pattern is the same but you do need to bore out the manifold a bit, that only takes 5minutes with a flap sander. The 4 wires for the throttle position switch need extending as the switch is turned 90degrees, & obviously you'll need a bigger diameter pipe to go on the end as its quite a bit bigger
[/quote]
Good one thanks chaps
Post 298127 by t5 stealth on 2010-03-25 21:44:44
[/quote]
did it make much improvement ,?
Post 298148 by WOODY T5 on 2010-03-25 23:00:40
yeah got a bigger thorttle body and inter man on my t5 pulls lot better with it on.
Post 298175 by p fandango on 2010-03-26 05:06:02
[quote=t5 stealth;298127]did it make much improvement ,?[/quote]
i changed to the 3"RIP kit at the same time (already had Volvo RIP) & yeh it transformed the car. When i first fitted the 19t it was that laggy i was thinking of going back to the 15g, but after the TB & RIP it spools just as quick (if not quicker) than the 15g. I did get the dremmel on the 960 throttle body as well before i fitted it (removed the internal ridge & smoothed out the butterfly)
Post 298190 by JUDGENINJA on 2010-03-26 09:41:14
In a Blue Peter Stylie - Here's one I prepared earlier...
http://www.vpcuk.org/forums/showthread.php?t=14029
Post 298314 by Alan M on 2010-03-26 21:59:12
Or just get a NA manifold and TB which will fit and be bigger (the TB that is). You will need to add some ports to the manifold to make it match the Turbo unit.
Post 298864 by gotmeaT-5 on 2010-03-29 15:48:30
[quote=Alan M;298314]Or just get a NA manifold and TB which will fit and be bigger (the TB that is). You will need to add some ports to the manifold to make it match the Turbo unit.[/quote]
Good one off to find a NA manifold
