96 850 T-5 instability bad handling
Post 301258 by gotmeaT-5 on 2010-04-09 13:12:21
my 96 850 T-5 Estate is handling really badly like its got hydraulic suspension. I have fitted new Drop Links, Rear Shocks, Wishbone bushes ideas on whats next? Springs maybe still on stock ride height springs P
Post 301263 by t5_monkey on 2010-04-09 13:23:06
Definitely get some IPD Rollbars - makes a world of difference, along with Sports springs. A strut brace will tighten things up nicely too, a Polybush engine mount will stop the engine flopping around too much too when you're on and off the power between corners. You had your suspension geometry done too?
Post 301267 by gotmeaT-5 on 2010-04-09 13:30:05
Steering adjusted too. IPD stuff looks good will get a pair from Eurotuning people as Partsforvolvosonline are charging way too much more than to import the stuff from the states. After front and rear anti roll bars that hopefully will improve the handling if not I will return
Post 301270 by t5_monkey on 2010-04-09 13:47:14
PS - it's basic put double check your tyre pressures too! :)
